Nice write up, glad you're enjoying your upgrade. However, I'm not sure that what you are experiencing is actually a result of ART, my guess would be that what you are experiencing can mostly be credited to the upgrade from a single to a dual sub setup since I experienced the upgrade in a very similar way (before ART and even before DLBC). Frankly, I would describe it almost exactly how you did - going from one to two subs in my room was huge (I had SVS SB 2000 Pros back then). Is the second sub in the back located closer to you than the one in the front? It kinda sounds like it from what you are writing. In my case I did set the subs up like that as well, one in the front between the R and C, which gives me a very flat response in my room and the second one very close to the MLP in the corner on the left next to my couch, which greatly improves the tactile feel at lower volumes.FYI: I went from ART with 1 to 2 subs and 2 subs is a clear improvement with ART as well
Post in thread 'Dirac ART is now running on beta FW for Denon Xx800H AVRs!' https://www.audiosciencereview.com/...a-fw-for-denon-xx800h-avrs.46616/post-2477175
Yeah, that's exactly how I was feeling about dual subs as well. It mostly gave me more sense of bass pressure and more tactile feedback at lower volumes. This was with Audyssey though, I ever heard a single sub with ART. I was very happy with the very deep bass with DLBC (when I had two Arendal 1S and especially after I got two additional SVS SB13U) what ART did in my system is it greatly improved the "punch region" - there so much more "kick" (which I would assume is mostly due to the better time alignement and crossover integration between the subs and mains of ART vs BC).Funny that you rate 1 sub so high. Does the 2nd not give you significantly more deep bass? That was the biggest improvement for me. The other also noticeable but the deep bass and more pressure in the room was striking....
I always wondererd though if my experience with going dual could also be achieved with a single more powerful sub. Maybe it was simply a case of getting more driver surfae area..? I remember when I first got a (single) Arendal 1723 1S, it sounded more impressive than even the dual SVS SB 2000 Pros with a lot of material because it had more punch than even the two SVS combined. Only the very deep bass kinda fell short of the dual sub setup and the two still felt a little more immersive but since the very deep bass is probably exactly what provides this "immersed feeling", going with an even more powerful single sub could potentially achieve sth simial as well (provided you have a position where a single sub works very good and you only have to worry about a single MLP)? Maybe it was just a case of subpar integration of the two SVS Audyssey though, which maybe didn't let them play up to their potential punch wise.. I would love to hear a pair of SB 2000 Pros with ART again or better yet a pair of ported subs (I also had a pair of SVS PC 2000s once) to see what ART could extract out of them.
That's a very interesting take - I guess yet another thing on my list to potentially try outIt seems that adding a second Arendal 1S subwoofer produced very good results. In my environment, even a single sub works well, but I would rate it roughly as 90 points with one unit, 95 points with two, 98 points with three, and close to 100 points with four. In a DLBC setup, I would say one sub is around 50 points and two subs about 80 points. The difference between one and two subs was significant there, whereas with ART the difference is not as large.
This is only a single Arendal sub in the front:
