OK, so my preliminary report on ART, X4800h replacing Integra DRX3.4 with DL (full range)
Initial cursory listening, with +4 / -3 target curve... is it any different?
Set up 2 presets :
- using the same DL parameters as I previously used with the DRX3.4 - the sound is familiary - it sounds just the way it has for the last couple of years - all good. (Good sign that the X4800 isn't doing anything wrong!) - target curve is following native in room response of my Gallo's
- set up with ART - using +4/-3 target curve
Ok there is a difference between the two - but it is probably due to the target curve... cannot be sure whether one is better than the other
Finding the profiles a bit bass heavy (I had used the tone control on the DRX to reduce the bass... really should have just adjusted the target curve!).
New set of 2 presets - targets set using "handles"/shelves:
- ART preset with +2 / -3 profile
- DL preset with +2 / -3 profile
Listened to a range of music... blues, jazz, classical, rock
There is a difference, but it is subtle, (a sign that my system & room are well sorted?) - but the ART preset seems clearer, not much in it.
Other half came in and sat down, then without prompting, she said, it sounds "lighter", less tiring, what have you done?
I then did a bit of switching back and forth with various tracks and both of us on the couch... yes ART is definitely a step up.
If I was in a smaller room with more acoustic issues, it might have a greater impact, but even so it has a noticeable impact.
Is it worth the AU$4000 spend (AU$3000 for the Denon X4800, AU$1000 for Dirac ART)... I'm not sure... but it did definitely progress the system positively.
Some notes about my room - it is very large - open living space with lounge/dining/kitchen and open hallway to rest of home - ceiling/roof is also vaulted/cathedral ceiling - so a substantial volume, and bass nodes/nulls are likely to be in the infrasonic range due to the space size - so the DL setup was already sounding pretty damn good.
Bass - I have mentioned before that I am not a bass head - my search is more for clarity, detail, texture.... which I am getting.
After further messing about I further lowered the bass end of the spectrum, and am now running with a "handles" based target at 0db, and treble at -3db
Fronts (24Hz) are supporting at -12db - supporting center, surrounds, front heights, sub -18
Center (50Hz) is not supporting anything
Surrounds (35Hz) - supporting Fronts -12, Surrounds -18, surround heights -18, Sub -18
Heights are not supporting anything (they are supported by fronts for FH, surround for SH, and all by Sub -18)
Sub - Supports all at -18, supported by Fronts -12 and Surrounds -18
Happy with the result...
Have yet to try movies - which may or may not need their own seperate preset with more of a bass boost - we will see...
Summary - a big subjective "Tick" for ART - subjective improvements in clarity (midrange and bass), music appears more "relaxed" (an outcome or removing the decay from the room?), imaging improve, but all the effects are subtle - nothing overt or obvious - no "wow" moment of enlightenment.
I think those experiencing the "wow" effects are most likely in smaller rooms with more issues.
I did not deploy the 2nd sub... don't feel the need.
