It's decay, not delay. (But group delay, GD, is reduced.)delay is reduced
correct, miss spelling from my sideIt's decay, not delay. (But group delay, GD, is reduced.)
ART will use your speakers up to their measured abilities. So there is no need to designate them as subs. They will be used by ART algo to support the single sub in the range they are able to. My best guess is that ART will assign them with 30-150hz range.Okay, but if I connect one subwoofer, how do I get the other speakers to their full range? And how does Dirac ART, which requires multiple subwoofers, work in this case? Your optional subscriptions are not available for sale in my country![]()
This is not true. You can use one or zero SW with ART if you choose. As a matter of fact, if you don't own a SW (and relying more on full-range speakers), then you don't even have to pay for the DLBC license (as confirmed by Dirac employee Flavio here and at AVS)!And how does Dirac ART, which requires multiple subwoofers, work in this case? Your optional subscriptions are not available for sale in my country![]()
I feel the same for now but in say 5 years, when I must downsize, I will definitely sell my multiple dacs, pre, power amps and do it all with an AVR..Not a huge fan of using receivers to play music, but that's just my personal preference.
A mediocre DAC, a mediocre pre, a below average amplifier.
Yes, I know, depends on the reference point to compare with.
There may be measurable differences, but none of that is audible.Not a huge fan of using receivers to play music, but that's just my personal preference.
It's not even close to my ears.There may be measurable differences, but none of that is audible.
Given you've never measured anything I'm highly skeptical. Sighted bias is a very real thing, as is level-dependent preference, etc. Read around here some more, you'll find we're big fans of backing up claims with measurements and no one has successfully shown a non-broken amplifier, etc, to be audibly detectable vs any other I'm blind testing. Speakers? Room correction? Absolutely. Electronics ? No.It's not even close to my ears.
Desktop: PC-->DDC-->DAC--->Pre-->Power Amp
An external clock to both DDC and the DAC.
Nice speakers too.
Vs. the Denon X3800H, even with fully external amplfication.
Never measured with anything.
Audibly - not even close, night and day.
But I never ever tried to "marry" music and the movies.
Assembled the office setup with one purpose, and the HT room with a different one.
P.S. Yes, receivers can play music too.
Why?Not a huge fan of using receivers to play music, but that's just my personal preference.
Sub ch 1 is LFEQuestion -when using multiple subwoofers how do you work out which sub ART has selected as the LFE channel? How does it select?
True - but the level of what is possible with a mediocre DAC and a mediocre pre has shifted massively from what those categories could achieve 20 or 30 years ago.Not a huge fan of using receivers to play music, but that's just my personal preference.
Does that mean you never got into SACD, DVD-Audio, BD Audio, or Dolby Atmos music?Not a huge fan of using receivers to play music, but that's just my personal preference.
If you insist on an objective measurement, the Denon X3800H measures pretty terriblyGiven you've never measured anything I'm highly skeptical.
www.audiosciencereview.com
Absolutely, it does.Does that mean you never got into SACD, DVD-Audio, BD Audio, or Dolby Atmos music?
Fully agree.It becomes a question of what is "Good Enough"...
Short version - the separate components are readily available, and you don't need to spend 10x the amount to get a MUCH better result, audibly, compared to any receiver.Why?
