Active Room Treatment (ART) by Dirac
I'm not sure if the M66 really needs ART.
2.4 channels is not a lot for a sound cancelling system like Dirac ART
That is 6 speaker sources. Depending on their locations I would be it could still do very well.
There are reports of benefits even from a 2.1 setup...
Eat this ;)
M33, M10, C399, C389 and C658 only have two sub outs and that should be sufficient for any speaker constellation.
Even 2.0 works, see also here: Link
That is what is so fascinating about ART.... not only do you have cancellation of flaws / nodes, but you have all speakers contributing to support...
So as long as you are running more than mono - the results are theoretically better with ART than without.
And the greater each speakers capabilities (frequency range, SPL etc...) - the more it can contribute
The big remaining question is: How much for this magic spell....?
I can only imagine what can be done with a set of active speakers.
With the degree of control a DSP offers, the possibilities are massive.
As I understand it, Storm Audio have an exclusive one year deal with Dirac. So you need to buy one of their processors, and it's about $20,000.
As long as the DSP and ART don't start to compete with each other!
The interesting thing is that with something like Dirac - a centralised DSP, one has to ask whether one needs DSP in the speaker?
Should there be a new breed of speakers that provide active amplification, but leave the DSP tuning up to the central processor?
Otherwise, you use the DSP to tune the speaker to optimum for the speaker... but then Dirac is going to adjust it further.... case of the battling DSP's?
Only (!) until October 2023 - then it is available to any manufacturer that has done the required firmware integration work...
So if D&M, or Onkyo, or JBL/Arcam etc... are doing the integration and testing quietly in the background, they have the potential ability to launch DLART on their products come October.
Those who only start work in October for the integration, probably won't have anything into the market until mid 2024.
On the other hand, Dirac seemed to imply that if DLBC is already integrated, then all the hard work has been done... and adding ART should be relatively easy.
A DSP can provide exact frequencies to each driver on a whole speaker, so even more precision.
It would be quite interesting to have a system like KEF LS series with ART compatibility. That would be super nice to set up from a usability perspective.
ART only works up to 150Hz as far as I know.
Is that because sound above ~200Hz is not omnidirectional anymore?
I can imagine that trying to cancel out higher frequencies would be more difficult than bass which is more predicable
Couple of points..
-Get in touch with a good dealer to work with as the actual price you pay can be much different than that
-Also, DLART is compatible on the MK1, MK1.5 (units that have been upgraded), MK2, and MK3. I have seem MK1/1.5 units around $6k or so.
DLBC has always worked very, very well for me for subwoofers. Where things can always get a little messy is the 80-150hz. In particular with higher crossovers on things like Atmos speakers where they need to have higher crossovers. The integration doesn't doesn't always follow your target curve (often times there can be a significant dip between 80-120hz). However with ART, that isn't the case since the user isn't setting the crossover for subs, the subs and all the other speakers help and those issues are not issues anymore with the help of more speakers. Also, for those with highly capable full range"ish" speakers there may not be as great of a need for 4 subs (1-2 might do it).
Well, the Core 16 will be capable of running ART and comes at ~14K (which is not cheap at all but at least considerably below 20K).
It seems that we already have a confirmation of bringing ART to the Monoprice HTP-1 and according to a German website to the Marantz AV 10, too. (And you and I might share hopes for more competitors to follow.)
As for the complexity of integration, I got a different impression. In a Youtube video after CES 23 Lars Mette said that StormAudio from their development perspective considered ART (not DLBC) the "second stage" with DiracLive 1/2/3 being the first stage. And we see that ART not yet is available on StormAudio products although a demo version was already there at the beginning of this year and despite DLBC already running.
ART has been in Beta with beta testers for several weeks. As far as I know, it is on schedule for release at the end of May on Storm.
The 150 Hz are the limit for the first version to be made available. The PC based software that beta testers got seemed to be capable of a higher limit already. IIRC somebody from StormAudio already mentioned a possible increase to 300 Hz.
If you want a more precise impression of what ART might be capable of please take a look at https://www.dirac.com/the-arrival-of-spatial-room-correction-technology/
The figures therein just from visual inspection seem to suggest that ART may bring benefits up to around 1 KHz (maybe even a bit beyond).
Couple of points..
Where would you place the mark on the "ish" of the full range? I assume the lower the better, but would reaching 80hz flat be good enough?
Dirac (and basically any other form of room correction DSP) can't properly correct frequency response deviations above the Schroeder frequency, because that requires knowing what the speakers sound like - they only know what the combination of your room + speakers sound like.
That's why I personally recommend that people only use room correction software to treat below the Schroeder frequency of their rooms.
Is ART correction separate from the crossover point?
If I set the bass control crossover point at 100Hz does ART still play anti sounds below 100Hz? And how loud are those anti sounds compared to the main signal?
There's no traditional exact crossover points when ART is active. All speakers (if desired and there's no dsp limits) play "anti sounds" and you can fine tune how low they are allowed to go.
So the ART signal is separate from the main signal?
Can I select a frequency interval for ART and a crossover point for bass management seperately?
I might want to have a different crossover for the main signal and the ART sounds which apparently are a lot lower in level and wouldn’t cause issues with smaller speakers as deep bass from the signal of that channel would do.
