AudioStudies
- Joined
- May 3, 2020
- Messages
- 718
- Likes
- 401
Do you prefer digital or analog crossovers in active monitors? Why?
Can this thought then make the case for having all active monitors equipped with digital inputs, and obviate the need for stand alone DACs in systems?While a skilled engineer can design a good loudspeaker with either a analog or digital crossover. The digital one has a lot more powerful tools in the toolbox. For a new design, digital is the way to go.
So then, is the reason we have stand alone DACs earlier in the chain than the powered monitors, just so manufacturers can make more money? Why not just have all powered monitors equipped with digital inputs? And why would anyone want to push the performance envelope with a stand alone DAC, if the signal will just be run through powered monitors anyway?Digital without doubt.
1) DSP based crossovers can have much steeper slopes than is practical for analogue.
2) Much more easily adjustable without any compromise on performance
3) Including EQ, both parametric and graphic is easy, and usually included.
4) Often can export or import settings from software like REW.
5) Can hold several sets of settings for different circumstances.
6) Much more repeatable, down to 0.1dB is trivial.
7) Can apply time correction for different driver positions much more easily than analogue filters.
I can't think of a single circumstance where an analogue filter would be preferable.
S
I can't see any reason why the crossover wouldn't be done by the DSP. Once the audio is in the digital domain crossovers are just maths.Does a pair of active monitors equipped with DSP automatically imply that the crossover is done in the digital domain? Also, does it seem like powered monitors don't offer a digital input option as often as they used to?
I don't have standalone DACs, I just run the analogue sources into my loudspeakers' ADC.So then, is the reason we have stand alone DACs earlier in the chain than the powered monitors, just so manufacturers can make more money? Why not just have all powered monitors equipped with digital inputs? And why would anyone want to push the performance envelope with a stand alone DAC, if the signal will just be run through powered monitors anyway?
Do you mean like vinyl and tape decks, or do you mean analog outs from CD player via a preamp to the powered monitors?analogue sources
Both. My turntables, CD player and SBT all go through an analogue preamp for source selection and volume control, then goes to the 'speakers through the ADC in the crossover/equaliser.Do you mean like vinyl and tape decks, or do you mean analog outs from CD player via a preamp to the powered monitors?
Curious why you don't go with all digital sources? Your analog sources are being converted in the powered monitors anyway.Both. My turntables, CD player and SBT all go through an analogue preamp for source selection and volume control, then goes to the 'speakers through the ADC in the crossover/equaliser.
S.
I think so too, so if a speaker is equipped with DSP, I just assume the crossover is digital.I can't see any reason why the crossover wouldn't be done by the DSP. Once the audio is in the digital domain crossovers are just maths.
S
I have to have source selection, signal routing and volume control and that's a lot easier to do in the analogue domain, then just do one conversion to digital in the ADC driving the 'speakers. The alternative is to use a separate ADC for the turntables then select just between digital sources, but that still leaves volume control, which can either be done in DSP, needing some sort of processor, or 6 way analogue after the crossover and before the power amps. Doing it in a conventional analogue preamp before one ADC is just a lot simpler. I'm not at all bothered by going digital to analogue to digital to analogue on my digital players as all my material is 16 bit and the converters are 24 bit, and a few extra conversions are so what.Curious why you don't go with all digital sources? Your analog sources are being converted in the powered monitors anyway.
Often but not always. The JBL 104, for example, uses DSP but features passive crossovers - one speaker of the pair is in fact completely passive.Does a pair of active monitors equipped with DSP automatically imply that the crossover is done in the digital domain?
As other people have said, implementing crossovers (and other facilities) in the digital domain has overwhelming advantages. I suppose one reason for considering active speakers with analog crossovers (implemented with op amps) might be serviceability. The Yamaha HS series uses analog methods and a service manual is available for it. I could imagine fixing a failed Yamaha HS (maybe) ... but something with a digital crossover ... not really! (Well, maybe it could be done if the fault was the "right sort").
Developer skill set and development budget. Analog monitors require:I think it is a good question why digital inputs to active monitors are not the dominant way of doing things these days.
