Not sure if you saw
@funkytech, but I
added another suitable build for bass absorbers.
I had a look at your photos and from my gut feeling* I would try to:
- Match the left early reflections absorber to the right ones. Symmetry!
- Ceiling cloud seems unnecessary long but that might be perspective error from the camera lens. I'd rather have 2 or 3 of these modules, maybe even in horizontal orientation (90° different to what's on the photos) to cover more ceiling surface from L to R. Verify the early reflection points on the ceiling are covered through your entire movement area of your mixing position
- On the rear wall I would put a bass absorber. Basically what you have in thicker and at a fixed distance to the rear wall. Here either broad band or more likely with a scatter plate (that's
something like this)
- Put as many appropriate bass traps in all corners, i.e. all 90° interactions of 2 walls where possible. Also behind the speakers. These not broad band as suggested before
*Of course the results should be verified by measurements and by listening - and the measures adapted accordingly.
How much absorption do your curtains contribute to?
