Hi everyone,
I’m looking for some advice on how to improve the acoustic treatment in my small mixing/control room.
First, a quick disclaimer: this is a rented apartment. I may stay here for a few years, but I cannot do any permanent construction work. In particular, I cannot open or rebuild the drywall ceiling. The height to the drywall ceiling is 2.85 m, and there seems to be some kind of cavity above it. So I had to work within some practical limitations.
My goal is not to build a perfect professional studio, but to make the room reliable enough to finish and judge my mixes with reasonable confidence. I mostly work in a nearfield setup.
Room / setup
The room is irregularly shaped. The front wall is 2.90 m wide, the rear wall section is 3.00 m wide, and the total left-side length is about 5.25 m. Ceiling height to drywall is 2.85 m. There are also 12.5 cm structural columns protruding in some corners.
I use Focal Alpha 65 Evo monitors with front ports. After many placement tests, the current monitor position seems to be the best compromise in terms of frequency response. The speakers are placed on stands; the stand height is 76 cm from the floor. Listening distance is approximately nearfield, around 1.4–1.5 m.
Unfortunately, I do not yet have a proper measurement microphone. All current measurements were made with an Aston Spirit condenser microphone through my audio interface. I understand that this is not ideal, especially for absolute high-frequency accuracy, but I assume it should still show useful trends in the low and low-mid range. Please correct me if this assumption is wrong.
Current treatment
The room already has quite a lot of treatment, maybe even too much in some areas.
Current treatment includes:
I have attached a room plan with the current acoustic treatment layout.
Main problem
The biggest issues I see in the measurements are around 105 Hz and 165 Hz. These problems seem to affect the right monitor more than the left monitor, although both speakers have their own problems.
The 165 Hz issue also changes noticeably when I change the measurement height, which makes me suspect some floor/ceiling or vertical-mode interaction.
There is also a strong low-frequency issue around 36–40 Hz, with long decay. I suspect this may be related to a room mode and possibly the drywall ceiling/cavity behaving like a resonant surface. Since I cannot modify the ceiling structure, I am currently trying to control this with monitor EQ / correction rather than construction.
Questions
I would really appreciate advice on the following:
Any advice would be appreciated. I understand the room is far from ideal, but I’m trying to get it to a practical, workable point rather than perfection.
Thanks!
Room / setup
Current treatment
- Full-height corner bass traps made from triangular mineral wool chunks.
- A large mobile absorber on the left side, built from four double-layer mineral wool panels.
- On the right side, at the first reflection area, there is currently only a single layer of mineral wool treatment.
- A large rear absorber panel behind the listening position, about 2.6 m wide.
- Ceiling cloud above the listening position.
- Additional broadband panels and curtains around the front/window area.
- One far corner is still untreated because of the room geometry and practical limitations.
Main problem
Questions
- Based on this room shape and treatment layout, what would you try next to improve the 105 Hz and 165 Hz problems?
- Could the asymmetry between the left and right side treatment explain why the right monitor behaves worse around these frequencies?
- Is it worth adding more treatment to the untreated far corner, or would that probably not affect the 105/165 Hz issues much?
- Since the 165 Hz dip changes with microphone height, should I focus more on speaker/listener height rather than adding more wall treatment?
- Given that this is a rented room and I cannot modify the drywall ceiling, what would be the most practical way to deal with the 36–40 Hz decay?
- How reliable are these measurements likely to be when made with an Aston Spirit instead of a calibrated measurement microphone?
Thanks!
