Valid, scientific evidenceWhat exactly is your thing?
Fallibility of memory on your part and of course no linkI think I recall you being very intractable in another thread despite substantial evidence
I think most of us simply don't know. If it has a better absorption coefficient it probably has to help. Beyond that many of us probably don't have the knowledge to help out.
Sorry, if my post seems of no help. I didn't want you to think no one was paying attention to you.
In REW you can do the room simulation where you input the coefficients of absorption. Perhaps you can look up likely values for your materials and do one with and without the stretched acoustic ceiling. Some will be guesses, and you have what sounds like a not rectangular room. Even with this changing the ceiling from a low coefficient to a larger one would give you an idea how it effect things.
Yes, forgot about that. If you are replacing the ceiling anyway, I don't see how you can go wrong considering the structure you described. It will be a step in the right direction at least in my opinion.Arf, it seems that the room correction limits to 300hz ....
Fleece - make sure it is treated with borax (flammability concerns). A few cm would help, thicker would be better (depending on the frequencies you need to absorb). 2.5 cm would affect midrange ~1Khz and above. 5 cm would get down to ~500Hz and above. (Rule of thumb: halve the freq, double the thickness)Let's not deviate from the orignal subject
The initial point was not not about double blind listening tests not about the look / quantity of absorber panels.
I should have been more precise in my request
I am interested about the impact, from a measurement standpoint, of an acoustics stretched ceiling (with damping or not) versus a regular stretched ceiling.
I am going to replace my current one anyway and I am wondering if the cost of the acoustic one will bring any enhancement, from a measurement standpoint.
If there is some, I will do it, otherwise I prefer not waste money. Then will it make make a listening experience change, that's an another point.
I was proposed this type of acoustic stretched ceiling.
Here are some absorption specs from concurrent solutions :
Regards,
Vincent
The most obvious reason is that it's impractical, if not impossible, to switch blindly between the two. And there probably be a WOULD be a difference in a blind test anyway and you'd probably know which is which.The people who advocate for so called acoustic treatments in domestic living rooms will never ever offer the gold standard of perceptual science - double blind listening tests, to support any such belief. For obvious reasons. However, no one (except the actual blind) listen blind at home. So if one believes in such things, the sight of, for example, this type ceiling, could have an effect, most likely positive. "Worth" it is a separate question, probably only answerable by the user after the fact.
That's not the point... The test should be blind to eliminate the effects of bias or expectation, and then after you've determined that you can or can't hear a difference and/or have a preference when you don't know what you're listening to. Your everyday listening doesn't have to be blind after that.However, no one (except the actual blind) listen blind at home.
It's going to reduce flutter echo and give some needed absorption. However, it's important to understand that a absorption coefficient of products is based on reverberation measurements, meaning it's only valid for very large rooms (concert hall size). The result will be different in a small acoustical space. The treatment wil be very bandlimited (altering the tonality) and will not attenuate apecular reflections well.Hi all,
I am seeking some advice for my current listening room which is our living room (about 30 m2 – 7.5x4 and 2.5m height).
One side is mostly bay windows, and the back left corner is opened on the kitchen and the hall. Other sides are concrete walls.
We are going to replace our current stretched ceiling (old lacquered PVC one).
I was wondering if using an acoustic stretched ceiling (micro perforated, absorption coeff of 0.3) on its own or coupled with a 5cm layer of acoustic fleece between the concrete ceiling and the stretched ceiling (would probably end up with an absorption coeff around 0.6 or 0.7) would enhance the acoustics, reducing a bit reverbs on medium / highs or would not change anything.
Acoustic stretched ceiling is twice more expensive than regular one and adding the acoustic fleece layer is additional work/cost.
Given,the attached REW measurements (current measurement is the ‘kanta+sub+dirac’ in the mdat file), would you think it would worth it ? or useless ?
Thanks
Frank is also misunderstanding/misrepresenting when it is necessary to blind test. Blind testing is necessary to tease out preferences between small differences, or to determine if a person who claims to hear something immeasurable actually can do this. If you have a clearly measured difference well above the threshold of hearing, it's generally not necessary to do a blind test to make sure that difference is "really" there. For example, if you have a room mode that's boosting 100Hz by 10dB and you're able to address it with EQ and room treatment and bring it down to flat, and you can demonstrate both with measurement, you don't need a double-blind test to "prove" anything. To say you need a double blind test to prove that someone can hear when a 100Hz signal is twice as loud isn't a commitment to scientific accuracy, it's just being obstinate.The most obvious reason is that it's impractical, if not impossible, to switch blindly between the two. And there probably be a WOULD be a difference in a blind test anyway and you'd probably know which is which.
Exactly. Wall treatment, speakers&listening position optimisation still needed, but since it would be almost invisible - greatIt's going to reduce flutter echo and give some needed absorption. However, it's important to understand that a absorption coefficient of products is based on reverberation measurements, meaning it's only valid for very large rooms (concert hall size). The result will be different in a small acoustical space. The treatment wil be very bandlimited (altering the tonality) and will not attenuate apecular reflections well.
So certainly better than nothing, but not great treatment.
