That's what this place is for!
It could well in part be a brain thing, you see the rack where the sound is coming from and it buggers up the illusion.I can only think If indeed it is truly harmful that it would be to do do with the off axis response of the speakers.
But the degree of off axis would already be steep ,at that point even with your speakers toed in.
Having a flat table I between you and the speakers would be worse .
AJ or Amir will know.
Keith.
See no issues with that. It actually acts like a scattering device which is good in the front wall.View attachment 917 I like many have the rack in between the speakers in the ' shrine' setup. I know this is not great but can some one please give a measured reasoning to this idea?
Yea they are a special wood, like the cardas ones. Tried all sorts and these ' sound' the bestDid you ABX those cable stands?
I have African hardwood stuck to my wall socket and distribution block...Mpingo?
DIY accident?I have African hardwood stuck to my wall socket and distribution block...
They have special topaz crystals on them to....
A lesson to handle your hardwood with care, try it in different places and know its effectiveness is probably over estimated..DIY accident?
Yo Don, that would be like, behind the speakers...and also incorrect, because even monopole speakers have significant rearward radiation, due to the trends of narrow baffles and small drivers, which are largely omni directional in the lower frequencies of their passband. Ain't nothing to stop that wrap around.Most speakers have little response 180 degrees off-axis and that seems like a good place for electronics and (especially) turntables.
You see the cursor position and the label saying -9.33 db at 7 Khz??? After that, it drops much more yet again. My quick read says -18 db at 20 Khz. Wouldn't call this barely 6 db down.Speaking of speakers, looki here at this Vivid:
Note that we are barely down 6db over a large swath at 90 degrees of axis!!
Well yeah, but I was referring to the ones specifically in this thread which we have data for (I think those are G3s)The radiation pattern of speakers is heavily dependent upon so many variables that there is no really hard and fast rule, at least for me.
Umm, low and in between?Where would you put the stand?
If you don't participate, how am I going to remember to remind you not to??Remind me to never post in any thread in which you are participating; I'll never match your level of acumen and expertise.
I would, especially at less than 90 which his picture clearly shows. He's going to have strong reflections of the shrine with that setup. Whether he finds it audible or detrimental is whole 'nother story.You see the cursor position and the label saying -9.33 db at 7 Khz??? After that, it drops much more yet again. My quick read says -18 db at 20 Khz. Wouldn't call this barely 6 db down.
Strong reflections from sides of equipment in that shelf? I don't think so. It is pretty airy in there and anything hitting them is going to then bounce off the wall and then get to your ear.I would, especially at less than 90 which his picture clearly shows. He's going to have strong reflections of the shrine with that setup.
Between front speakers was always popular for me, especially with planar speakers that have little radiation to the sides.
