MT_bassbone
- Joined
- Dec 22, 2024
- Messages
- 117
- Likes
- 25
I am building the Heissmann Acoustics DXT MON-182. I have the tops and sides cut. I noticed a small discrepancy in my dimensions. Top to bottom is 2 mm longer, and side to side is 1 mm shorter. If my calculations are correct the internal volume is .007896 cubic liters larger than the plans. Is that problematic? In my mind I think larger would be better than smaller. Thoughts?
The box is square and the miters look good so I am hesitant to remake the pieces. It does make the width a bit shorter so its even a tighter fit for the PR on the back of the box.
