- Thread Starter
- #161
In which case they were outputting the same digital signal to the DAC. So you listened twice to the same DAC. Or did I misunderstand something?These were connected to an external Dac
If i am correct one was output coaxial the other output optical into similar IN of the dac . Could switch with input selection of dac remote controlIn which case they were outputting the same digital signal to the DAC. So you listened twice to the same DAC. Or did I misunderstand something?
That’s because the digital output was the same between the two CD Players, and the DAC output was the same too.I did not find listening differences between the two cd players playing same CD at the same time,
I had to smile when I saw how thoroughly they check the casing and front panels for tiniest schratches and rejected one sample because of a tiny scratch invisible to the camera. When designing a prototype I had a test sample of aluminium brushed / beadblasted anodised by about 20 companies in Germany and they all failed to do this flawless... About the German cometitor Burmester the legend goes that he contacted 200 companies to polish and put chrome on their front panels until he settled on one. 99.9% oft them did not understand that flawless means flawless. But this quality comes to another cost besides the price: Best results are achieved with primary aluminum,the aluminium that is "fresh" out of the earth and needs to be processed with a lot of energy and poisoneous chemicals. The reason: 70% of the aluminium on the market is recycled and whereas the alloys do meet the physical specifications, they are not pure when being recycled as you do not get completely the other metals out of the melt. Though such impurities are less than 0.5%, anodizing shows them. Hope I described this well, I am not a native english is not my native language...OK, another Accuphase tour spoken in English!
Incidentally, I own a few BU-1C drives, which are fitted in the Accuphase DP-70 and DP-80. They were part of a project in which I wanted to develop a CD player from scratch, using linear drives as the basic principle – the patents and copyright for the system (and for the CD in general) have since expired. To extend the lifespan of the Sharp LT022MC laser diode (which was the only laser diode available at the time and is found in every CD player manufactured between 1982 and 1985), I increased the values of the feedback resistors for the op-amps that amplify the laser signal from the photodiodes. This trick can be used to reduce the laser current. It does introduce a bit more noise, but it is filtered out during the formation of the eye pattern. By the way, the laser runs along one side of the steel rod via a ball-bearing roller—the roller can be adjusted for height, allowing the laser to be realigned so that it is perpendicular to the plane of the CD.It is very clear, thanks for the insights!
Doesn't find my 30 year old transportVintage-audio-laser.com
They focus primarily on first- and second-generation CD players. It was a time when, so to speak, precision engineering and tradition met new technology…Doesn't find my 30 year old transport![]()
Excellent I found my first CD player, a Sony CDP101 and my second, the CDP-552Es and DAS 702ES. The 552 stopped working when my son had it but the DAC still worked fine when I last tried it.They focus primarily on first- and second-generation CD players. It was a time when, so to speak, precision engineering and tradition met new technology…
It really isn't and I don't understand how that myth has prevailed so long.CDP-101 is an atrocious sounding player
Souzoukan Technical Report is one of the best Youtube channel about hifi electronic and loudspeaker techniques.It really isn't and I don't understand how that myth has prevailed so long.
This video includes some basic measurements (from 5.35) and an A/B sound comparison between the player and modern streaming system at 8.28
My brother just bought a second hand Accuphase dp600 which is using this Sony pick up. I emailed Accuphase jp to know whether some khm230aaa were still available in case of failure and the answer is no6'37'' in the video, top left corner: a box (full of?) Sony KHM-230AAA laser optical pick-up mechanisms.
The optical pick-up used in Sony SCD-555ES, SCD-XA777ES and SCD-XA9000ES amongst others and unfortunately known to loose its ability to read the SACD layer of hybrid discs over time (although this very mechanism in one of my disc players still works flawlessly after 25 years of operation).
My own sony scs 555es suddenly stoped reading sacd and hybrid sacd discs a few months ago. However, the red laser dedicated to the sacd layer is still glowing. Electronic or mechanical issues may be involved as you suggested.This make me think that a knowledgeable technician should properly investigate the failure mechanism of this pick-up, because there are some clues that it may be related to some mechanical issues rather than laser diode break down.
Bad choice! They are not repairable. Same for the older 7xx, 8xx, 9xx. Maybe the 950 and 1000 still are, from the older models.My brother just bought a second hand Accuphase dp600 which is using this Sony pick up. I emailed Accuphase jp to know whether some khm230aaa were still available in case of failure and the answer is no![]()
