Absolute Polarity - Myth or "Important"?
  • Thread starter Deleted member 23982
  • Start date
Thomas_A
Sweden
My thought was that most people can hear it after some training. If not what are the reasons for its audibility? Ear physics or processing in the brain?
solderdude
The Neitherlands
As long as you don't hear it don't try to hear it ?
Besides for a lot of people the differences, even when audible, do not 'degrade' or alter the music itself in any way and o not really care about a specific aspect.
markus
Thomas_A
Sweden
”Is there a hard cut at the beginning (and ending) of each sample or did you use a small fade in? Hard cuts often produce audible artefacts, i.e. you might be hearing the edit not the polarity inversion.”
I would say this would not affect. I get the same results with Solderdudes Alison Kraus file. The audible difference is in the timbre.
Thomas_A
Sweden
While on it, how do you find the short piece of Yoshikazu Mera? Can you play it loud on your speakers and still feel it is pleasant to your ears? It is one of my killer tracks when evaluating speakers.
600_OHM
Hmm.. couldn't find any audible differences in those test tracks either, but thanks for doing that.
I'm going to have to test some more on percussion, where perhaps I'm losing my touch for detection. This thread has surely been enjoyable.
One thing for sure, my joking research on triangle-solos actually turned up some great info about how to play them properly and even includes FR charts! I truly had no idea there was a lot going on!
Once I get done listening to MB's "In Search Of The Lost Chord", I'm going to go back to see if I can do a test setup like solderdude mentions, and go in search of the lost pecussion strike and document it. :)
DimitryZ
Waltham, MA, USA
Well, thanks to @solderdude , I have a handy AB switch at my listening chair to flip phase at the preamp/amp interface.
And on most modern music it doesn't make a noticeable difference. I suspect modern recordings have many tracks in both normal and reverse phase due to many, many processing steps.
On old recordings (in my case, jazz from 1950-1960s) there is often a difference, but again not a consistent one. Vocals sound better with one phase, base sounds better with another. For music you really enjoy, listening twice is wonderful.
So a fabulous tool to have at your disposal... sometimes. It seems that in balanced equipment, where both phases are available, we should have this feature built in.
If you ask nicely and pay the modest price, he may make one for you. Nice looking, too.
Wolf
Indiana
12dB slopes mean phase/polarity reversal, not so with typical 4th order acoustic slopes.
And yes, 1.5vdc is fine on a tweeter for a polarity test. It's also easier if you don't have access to a scope.
I want to add to NOT do this on a ribbon, as it will stretch out the membrane and require a replacement.
Dustyc
My integrated amp has a reversal switch on the remote. Seems like most simple miked recordings I can hear a difference but anything from the past 15 years it's a toss up . I usually listen for a change in the bass line. Nice feature to have though, and in the digital realm should be easy to do?
Flaesh
Eburg
Bob Katz's popular track "Discovery.." with an undoubted absolute polarity:
:cool:
krabapple
waveform of the final product doesn't prove that polarity never changed in the production chain.
ctrl
.de, DE, DEU
That there is a difference is not hard to hear with headphones. Which version is the one with inverse polarity might be more difficult.
I think an experienced audio engineer might be able to recognize the original with the correct polarity, at least for certain instruments.
Who wants to test it, here is a post with the link to the Audiocheck website and two test files to download for a blind test in foobar or similar.
René - Acculution.com
I think that it should also be discussed that the shown music signals are not what come out of the loudspeakers, and so it becomes real squirly to discuss absolute polarity unless under some controlled conditions. I will not make a long post, as I have already made a long video about my take on loudspeaker phase, polarity, and similar topics.
Thomas_A
Sweden
IMO, the "sensitive" frequency region for polarity switch is from 100 Hz up to about 800-1000 Hz. Of course speakers can mess upp this region with crossovers, but using speakers where crossovers are outside that region, there will be audible differences also using speakers for these asymmetric music signals, when flipped.
