About Tweeter Capacitor.
@solderdude
Thanks, now I'm VERY satisfied with how it sounds. Just need to test 6khz later when the inductor arrives.
I have a pair of this 1-way Full Range crossover (WEAH HB01). Could you or anyone give opinion about it from the photo ? I notice you mentioned something like LCR filter, which this item is described as
Brightness is in the 3-6kHz range which the tweeter does not do so any perceived brightness is in the FR driver.
That one can fix with a LCR filter.
WEAH-HB01-Haut-parleur-r-seau-professionnel-4-pouces-gamme-compl-te-synchronisation-morte-crois-LCR.jpg
The value of the capacitors are both 4.7uF, BUT the resistor is 3W1K8J , is that 1800 ohm ?? isn't it reducing the dB by too much ? Because my fullrange sounds not loud anymore so I don't use it. Or maybe I should remove that resistor to make it loud and use only what it filters without crippling the loudness?
The resistor is fine. It just lowers the Q factor a little or bleeds the capacitors when the switch is open.
Do you have the schematic. It may not be intended for that speaker.
Reactions: jst
I don't have it, it didn't come with one. The item is described as a 1-way Full range crossover/ LCR filter but yea it's not a custom made for specific speaker, it's a generic one.
Does this work as schematic ? I've mirrored the image so the location should fit
Description
Report Item
Product descriptions
Excellent audio enhancer
* This product is exquisite in workmanship and materials, and adopts circular inductor with polymer magnets, special audio large capacitors and so on. Apply to full-range speaker less than 4 inch. This product can adjust the sound quality by switching.
*Inductance: 0.29mH
Capacitance: 4.7uF + 4.7uF(switch)
* The product adopts 4 solderless terminal blocks. Convenient installation, exquisite appearance and beautiful sound quality is our traits.
Brand Name:WEAH
Model: HB - 01
Divider Type:Notch/Wave Filter Crossover
Output:Full Range Speaker
Impedance:4~ 8Ω
Apply to Speaker: Less than 4 inch
With my minimum knowledge about this, my 'Guess' would be : the fullrange will be xo-ed at 4311Hz , from this calculator
Using our previous calculator, that sounds about right, I have to use 4.7 uF capacitor to an added tweeter to match it at more or less/close to the same frequency
Am I right, or totally wrong lol ?
But why does it have 4.7uF cap in there too, it even has TWO caps 4.7uF, isn't it for tweeter to remove low frequency ? while the inductor is for cutting the high which is understandable. Or is it combined to 9.4uF which 10-33uF is used for mid driver.
Does this kind of Resistor work for tweeter ?
ok.. it is an inductor (unknown value) with a capacitor in parallel.
The switch can parallel an extra capacitor to it lowering the resonance frequency and giving a bit more treble.
The 3.3ohm will work in this case as there is hardly any energy above 20kHz.
Reactions: jst
What capacitor would be the ideal one for a tweeter of 4Ω?
I want to go active in a car and would like some protection. I see some conflicting information online and here.
All I want is to run Tweeter at 3kHz HPF and want it to be protected from amp pops and accidental DSP resets, as well as blocking anything below 2.5kHz or blow to be cut off.
15uF bipolar capacitor will do that but not all tweeters like to be filtered that low with only 6dB/octave.
Here is a filter table, in Swedish but you probably understand. Highpass=Högpass/Högp. Lowpass=Lågpass/Lågp:
Screenshot_2026-03-22_074432.jpgScreenshot_2026-03-22_074453.jpgScreenshot_2026-03-22_074423.jpg
If you add a coil (spole/drossel), you get a 12 dB filter.
6 dB per octave means in the case of 2.5kHz crossover point, so an octave lower is 1.25 kHz there it is 6 dB lower. With 12 dB filter at 1.25 kHz 12 dB lower and so on.
The lower the crossover point with a tweeter the steeper, higher order filter you need to not stress the tweeter. To reduce distortion.
The phase aspect of different order filters should be weighed in the equation.
