The overwhelming majority of quality-brand vintage amplifiers from the 1970s to the early 1990s are going to be Class AB designs. Some Class D amps do exist from the old days, and there are some higher-end amps that are exclusively Class A. But Class AB was by far the dominant topology for full-size component integrated and power amps (and as far as I know receivers).
As for power, I am not a big believer in power conditioners when it comes to allegedly producing subtle improvements in the sound. However, I do believe various types of power treatment can help in certain situations. For example, a lot of municipal power grids - or even just your home electrical wiring, if you have certain "dirty" appliances - produce some DC in the AC line. That can cause components with large transformers, especially toroidals, to hum. The sound doesn't come out of the speakers - it's a physical/mechanical vibration that comes directly out of the amp itself, and often it cycles. A DC blocker plugged between the amp and the wall socket can easily eliminate this problem, or at least reduce it to the point where you have to put your ear right up against the amp to hear it.
Similarly, sometimes a voltage regulator can help extend the life of components if your local AC power grid has an unusual amount of voltage fluctuation.
