AB amplifier heat dissipation
Jupije123
Hello, the only place I can place my Marantz pm6006 is underneath the credenza. This leaves a 3.5 cm distance from the top surface of the amp to the lowest surface od the credenza. Is that enough distance for heat dissipation? Horizontally in both directions the flow of air is unobstructed.
I dig these little guys anywhere heat/airflow is a concern. On my AVR, on my Modem/Router, on my DTV Genie by the HD heatsink. Inaudible at lowest setting, and USB powered.
I put my laptop on my PM6005... Life of living in the second most expensive city. So far it hasn't died yet.
You even have 3.5cm of space, you'll be fine.
