onethreetwowaitthatswrong
Hi folks,
Apologies in advance if this is the dumbest question ever, but I haven't found an adequate solution yet, so here goes :
I use my main audio system [Cambridge CXA 61 to Focal Aria speakers and a sub] to play movies as well. These are played from a computer, using vlc, and audio is sent to the amp via bluetooth, via this dongle. Problem is, when the audio codec of the movie is either A52/AC3 or DTS audio, instead of sound, I have an abominable avalanche of whitenoisesque audio mess.
I've tried several things, among which fiddling with vlc parameters, changing spdif out to another of the output options available for the dongle (either same result or no sound), sent the sound to my wiim mini, then to the amp via optical, aux out, and aux out to analog in, directly connect the computer to the amp via USB (same ear-destroying result), to only quote those I remember at the moment. The only thing that worked was to transcode the entire movie audio to a codec that works, but that takes a really long time, and, when I did it, the audio quality felt off (though I could not really compare to the original one, since... I can't make it work).
So my question is : how to solve this problem, in the less time and money costly manner that ensures some degree of audio fidelity ? Is there a specific device for this ? Home-theater pre amps look like they're here for it, but they cost thousands, isn't there a simpler device able to do the same ? Is it better on the software side, like is it something in vlc or another software that can be adjusted ?
