A1 Evo AcoustiX vs Dirac Live vs DLBC vs DIRAC ART in a 2.2 front setup (Denon X3800h, KEF R3 meta, SVS 2000 pro)
I was busy with home renovations this last year and now that we have moved, I am getting back into things and need to re-calibrate my theater and am wondering which rabbit trail to follow.
Here is my setup and goals:
Usage: Pretty evenly between video games, movies, and music (via laptop).
6.2.4 setup (phantom center) with additional tactile setup with: HoverEZe and BossBack
Amp: Denon AVR X4400H
L+R amp (connected to the pre outs on the reviewer): 3e Audio A7
Subwoofer amp: Behringer NX3000D
Tactile amp: Behringer NX3000D
Speakers:
  • L+R = DIYSG HTM 12 v2
  • Surrounds = Energy e-XL bookshelf speakers
  • Atmos = small Sony satellite speakers
  • Subs = Two Mach Audio 18" subs in two Marty Cubes
  • Tactile = HoverEZe (bass shaker with two 18" subs under the couch) and a BossBack (very near field open baffle 10" subwoofer in the back of the couch
I have a Umik-1 microphone and am reasonable with using REW (although endless things to learn).
Questions:
Speaker full range correction?:
My thoughts on equalization is that I would just correct below the Schroeder frequency for all the channels but then would like to EQ full range for the HTM 12s as they have outstanding directivity and klippel measurements (https://www.erinsaudiocorner.com/loudspeakers/diysg_htm12v2/) that show room for improvement with the primary frequency response and thus are prime speakers for full range EQ. I would be happy to manually do the high frequency EQ as I have done that before (https://www.audiosciencereview.com/...m-gated-nearfield-klippel-measurements.24533/) but I don't know how to add that to the EQ file (is it a ady file?) that would be generated from one of the EQ programs.
Subwoofer / Tactile Response Questions:
My second question is how to best manage the 2 subwoofers and 2 Tactile sub systems?
Currently, I have Sub 1 output going to a Behringer amp that goes to two independent 18" subs and Sub 2 output goes to a Behringer amp for the HoverEZe and back sub.
Should I keep it the way it is and then manually align the 2 subwoofers as a group and if so what's the best stepwise process for this (as it's been a while since I did this and I think I used acoustic timing references and REW to phase align them to get the ideal distances)?
Then should I use the eq capabilities of the Behringer to take down major peaks and then use whatever eq solution to do the granular details? Or should I fully EQ the subwoofer with REW and the Behringers 8 eq filters (as I am comfortable with this and done this in the past) and then run the EQ program as the final layer? Or should I leave it all to the EQ program to eq the subs one time aligned?
I guess an alternative thought I had was to use each subwoofer outputs for each 18" sub and then I could use whatever EQ program to deal with each of them individually. But then that leaves the question of where would I steal a signal for the Tactile subs? I was thinking I could use a Y splitter off the L+R pre outs that are already being used and then route the split signal to the Behringer amp for the tactile subs and the other signal to the 3e Audio A7 Amp for the L+R speaker. Would that degrade or compromise the signal for the L+R speakers? But then in this case I would need the L+R to be set as full range and a double bass system and ensure that whatever EQ system is used that it does not touch or alter the signal below 80hz as I would be manually looking after that time alignment and EQ of the tactile system myself after the EQ program has been done as I think the EQ program will not understand what all is going on with the tactile system and don't want it touching those frequencies.
Any other ideas where I can get a subwoofer signal for the tactile system? Or should I just keep the two subs as a group for one of the subwoofer output and then the other subwoofer output for the tactile setup?
Ok now that you have all the information and my questions.
Which EQ rabbit hole should I go down? A1 EVO AcoustiX? A1Evo MJ Custom (MJC)? +/- should I layer on GSonic Reference at the end for laptop music listening, or just pay for GSonic Evo 32?
Thanks for any thoughts or direction as I am happy to go down a rabbit trail or two, but want to avoid going down too many of them.
Thanks again!
What's your budget? I recommend A1 Evo Acoustix first and then if budget allows Dirac ART. That's roughly the path I did.
No, plug each sub to your X4400H's independent sub outputs. They will be measured separately and calibrated as a bass array with the fronts.
Start with AcoustiX, it's free, quite capable and customizable. For Evo 32, better read user reviews and decide for yourself:
Sounds good. Thanks for the feedback, directly from the source!
Would you bother with any time alignment as you outlined here, before doing AcoustiX, or just let it do everything?
Also, would you take down any majorly offensive peaks with the PEQ capabilities of the Behringer amp before running AcoustiX? Just seeing if there are limited EQ capabilities and if getting it into the right range would be beneficial before doing the EQ.
Thanks!
Leave it all to A1X.
No, turn off any and all processing between the AVR and subs.
Perfect! Thanks!
Last question (I think): is it possible to have A1X do full-range correction for just the L+R? Or can I alter the .ady after the fact if I want to try EQing the L+R as I had done previously? I would just be curious to see how it sounds will full range EQ. I know the general recommendation is not to EQ above the Schroeder frequency but I think these speakers would be a prime candidate for it, and I would be curious to try both.
I will post again when I finally get enough time to do the EQ and can post my results.... but baby #3 is due any day now so we shall see how much free time I have.
Default EQ is up to about 200-250Hz and can be increased to 500Hz individually for each speaker pair. Above that, you can use custom EQ filters and it will be added to the calibration. A1X uses min phase filters and high frequency eq is not a good option, serves only to the eye not the ear.
Hi,
I have played around with A1X and have been very happy with the results!
I know that I am not supposed to EQ above 250-500hz, but I have a pair of HTM12s that have fantastic normalized directivity, as confirmed by measurements, and thus would be prime for a more 'active' full-range EQ.
Because of this, I was wondering if there is any way to make a high-resolution EQ in the upper frequencies just for my L + R speakers.
I was thinking of using gated measurements at 1m for the EQ source measurements, as those would be much more accurate than MLP measurements.
I know @OCA you have talked in the past about making a minimum-phase filter based on the inversion of your measurements but I don't know if this can be done and layered onto the custom EQ that can be done with A1X.
Anyways, if anyone wants to take a look at my measurements and help with the EQ files that I can add to A1X I would be forever grateful.
I have the measurements that I have from using the Audyssey mic at 4 positions that is used for the base A1X, the A1X results, and then I have a single measurement with my UMIK-1 at the MLP, and then a 1m gated measurement with the speaker in the middle of the room. I was hoping to use this gated measurement to generate an EQ file ~1,000k-20,000k.
Here it is:
Let me know your thoughts. I know this is not typical, I just think in my case it is not unreasonable with that amazing directivity but sub-par frequency response.
Reactions: OCA
Gating doesn't really remove reflections, that requires gating at 0ms which will deem the measurement unusable. It can reduce contamination from room reflections, but it cannot reliably distinguish the speaker's direct response from reflections arriving inside the gate. It can also introduce frequency response artifacts depending on the window and gate length. Furthermore, response will suffer from decimation of frequency resolution.
HF EQ based on spinorama data could be useful in rare cases like high directivity speaker if done with linear phase filters but AcoustiX filters are min phase by design.
You might wanna experiment with a low Q (like 1) -2dB peaking filter around 1.2kHz if you wanna trim some of the brightness based on your results. You can do this using customization menu.
