A tool to convert REW/APO EQ to AUNBandEQ or RME EQ
pierre
Switzerland
EDIT: I added support for eqAPO, autoEQ and RME audio interfaces.
EDIT: software is also available as a web app with 0 install : https://eqconverter.spinorama.org/
When you use REW on a MAC, an easy way to apply the generated EQ is provided by Apple: AUNBandEQ is a plugin implementing IIR filters.
REW created an output for AUNBandEQ with frequency/gain/width for each filter.
I usually manually copy each data (3 per filters, up to 16 filters) to the plugin. This is error prone and boring.
I created a small script that takes the eq file generated by REW and generates a AUpreset (a configuration file for the plugin). You then only need to drop the AUpreset file on top of the plugin window and magic, all parameters are set.
Apple is not very transparent on how the AUpreset file is generated. After some reverse engineering, I have found a likely mapping of the data. I do not guaranty that it will always works and/or that Apple will not change the format over time.
This is an alpha version but it can convert
Code:
Notes:L w/sub
AU_N-Band_EQ
Number Enabled Control Type Frequency(Hz) Gain(dB) BW_Oct Bandwidth(Hz) TargetT60(ms) FilterT60(ms)
1 True Auto PK 34.25 -9.10 0.62 14.83
2 True Auto PK 109.0 7.40 0.19 14.37
3 True Auto PK 123.0 -7.10 0.25 21.34
4 True Auto PK 177.5 2.30 0.19 23.39
5 True Auto PK 197.0 -6.50 0.22 30.07
6 True Auto PK 221.0 6.30 0.27 41.42
7 True Auto PK 246.0 -7.00 0.27 46.11
8 True Auto PK 292.0 6.00 0.24 48.63
9 True Auto PK 328.0 -7.50 0.52 118.9
10 True Auto PK 683.0 2.80 0.19 90.01
11 True Auto PK 1202 4.50 0.21 175.1
12 True Auto PK 1964 -7.50 1.39 1966
13 True Auto PK 3068 6.80 1.39 3072
14 True Auto PK 3962 -9.90 0.34 935.9
15 True Auto PK 4780 1.80 0.98 3310
16 True Auto PK 6263 -5.40 0.37 1611
into
Code:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
    <key>ParametricType</key>
    <integer>11</integer>
    <key>data</key>
    <data>
    AAAAAAAAAAAAAABRAAAAAAAAAAAAAAPoAAAAAAAAB9AAAAAAAAALuEIJAAAAAA+gwRG
    ZmgAAE4g/HrhSAAAD6QAAAAAAAAfRAAAAAAAAC7lC2gAAAAAPoUDszM0AABOJPkKPXA
    AAA+oAAAAAAAAH0gAAAAAAAAu6QvYAAAAAD6LA4zMzAAATij6AAAAAAAPrAAAAAAAAB
    9MAAAAAAAALu0MxgAAAAA+jQBMzMwAAE4s+Qo9cAAAD7AAAAAAAAAfUAAAAAAAAC7xD
    RQAAAAAPpMDQAAAAABOMPmFHrgAAA+0AAAAAAAAH1QAAAAAAAAu9Q10AAAAAD6VAyZm
    aAAATjT6KPXEAAAPuAAAAAAAAB9YAAAAAAAALvkN2AAAAAA+mwOAAAAAAE44+ij1xAA
    AD7wAAAAAAAAfXAAAAAAAAC79DkgAAAAAPp0DAAAAAABOPPnXCjwAAA/AAAAAAAAAH2
    AAAAAAAAAvAQ6QAAAAAD6jA8AAAAAATkD8FHrgAAAPxAAAAAAAAB9kAAAAAAAALwUQq
    wAAAAA+pQDMzMwAAE5E+Qo9cAAAD8gAAAAAAAAfaAAAAAAAAC8JElkAAAAAPqkCQAAA
    AABOSPlcKPQAAA/MAAAAAAAAH2wAAAAAAAAvDRPWAAAAAD6vA8AAAAAATkz+x64UAAA
    P0AAAAAAAAB9wAAAAAAAALxEU/wAAAAA+sQNmZmgAAE5Q/seuFAAAD9QAAAAAAAAfdA
    AAAAAAAC8VFd6AAAAAPrcEeZmYAABOVPq4UewAAA/YAAAAAAAAH3gAAAAAAAAvGRZVg
    AAAAD64/5mZmAAATlj964UgAAAP3AAAAAAAAB98AAAAAAAALx0XDuAAAAA+vwKzMzQA
    AE5c+vXCk
    </data>
    <key>manufacturer</key>
    <integer>1634758764</integer>
    <key>name</key>
    <string>test</string>
    <key>numberOfBands</key>
    <integer>16</integer>
    <key>subtype</key>
    <integer>1851942257</integer>
    <key>type</key>
    <integer>1635083896</integer>
    <key>version</key>
    <integer>0</integer>
</dict>
</plist>
The data field is not very well documented, my guesses are:
- uuencoded block
- data is bigendian, 4 bytes for each parameters, parameters comes in pair (key, value)
- first 5 are
- 0
- 0
- number of parameters +1 (uint32)
- 0
- gain (float)
- then 80 parameters (16 eq with 5 parameters each): details
Ideally this would be implemented directly in REW (@JohnPM).
Also, many thanks for creating and providing this conversion methodology. Works like a charm, and bypasses having to manually enter EQ parameters, by quickly converting the output from Room EQ Wizard.
Thanks you so much @pierre for putting this together! Is this by any chance limited to 10 filters?
Whenever I open the resulting presets in the AUBandEQ effects in SoundsSource, there are never more than 10 filters, regardless of the number of filters in the REW output.
It looks like the first 8 are fine & the remaining are combined into the final 2, just looking at the mismatched parameters in bands 9 & 10.
See here:
On further review, this appears to be a SoundSource issue... some combination of turning off and on the AUBandEQ effects "wakes up" the correct parameters (or at least the UI).
Again, MANY THANKS!!! :cool:
This tool is exactly what I have been looking for. Unfortunately, I know nothing about python or how to get it to run. Any pointers?
Hi @IPunchCholla - the beauty of most / many programs on the web is that you often don't have any real python or other. programming skills.
It looks like you might be a Mac user, but the general flow for any platform is;
- Make sure python & git are installed - I'll leave the specifics to you, but just search install python, git, etc. on your OS
- Copy the code to your machine: % git clone https://github.com/pierreaubert/AUpresetConverter
- Change into the newly cloned code directory on your machine: % cd AUpresetConverter
- Make sure the appropriate python packages are installed in order to run the program: % pip install -r requirements.txt
- Convert your rew output file: % ./rew2aupreset.py -i [./path./to/your/rew/output/filter_name.txt] -o [~/Library/Audio/Presets/Apple/AUNBandEQ/filter_name.aupreset]
Then, if you're running SoundsSource, the filter should show up in the Presets dropdown in the lower-right of your AUBandEQ effects window.
Hope this helps.
Hope this helps.
Thank you! Nothing like command line to make me feel stupid. I am still having these two issues: pip is not recognized as a command. And: no matter the path I put in, it will not find my file.
I have a Mac m1 Mini. I have home-brew installed. I used that to install bot git and python for previous projects. I just ran updates to make sure I am on the newest stable versions. the code is cloned to ~user/AUpresetConverter. The filter output from REW is saved as a txt file in ~user/downloads.
pip returns the error that it is not a recognized command. All combinations to ~user/Downloads that I can think of give an error of "no matches found".
I - and many thousands with python experience - feel your pain. : )
Have no fear! We'll get you through this.
You may want to confirm which python you're using: % which python
And this: % python --version
Check this out for installing pip: https://phoenixnap.com/kb/install-pip-mac
(although, I'd bet it's already installed and there might just be a missing symlink somewhere)
if you are using homebrew:
add it to your path if not already done
> export PATH=$PATH:/opt/homebrew/bin
then install python3.10
> brew install python3.10
if you do a
> which pip3
you should get
/opt/homebrew/bin/pip3
then
> python3.10 ./rew2aupreset.py -i [./path./to/your/rew/output/filter_name.txt] -o [~/Library/Audio/Presets/Apple/AUNBandEQ/filter_name.aupreset
should work.
I get an error for either of those commands, unfortunately. It just says python not found. if I then use brew install [email protected] it says I have to use reinstall rather than install. reinstalling gives the message python not found.
@pierre Thanks. When I run which pip3 I get "/Library/Frameworks/Python.framework/Versions/3.11/bin/pip3"
It seems to recognizes the command python3.10 ./rew2aupreset.py -i [./path./to/your/rew/output/filter_name.txt] -o [~/Library/Audio/Presets/Apple/AUNBandEQ/filter_name.aupreset but no matter what I use for the path to the file (even dragging the file into the command from the finder) I get the error zsh: no matches found.
I assume the AUNBandEQ works on both stereo channels and there's no way to use it in dual mono with different settings?
I was just looking for such a tool,
Unfortunately, Kushview Element I use with AUNBandEQ only seems to be able to import .elpreset (its original preset file) , so I could not use .aupreset:facepalm:
I am continuing to look for an easy way to import EQ settings on my Mac, and may better install SoundSource instead of Kushview Element.
Pierre, thanks for this, but it doesn't work for me. Most of the example files don't seem to work (though some do). Unfortunately I don't know if the problem is SoundSource, Apple, or your tool--as you note, Apple isn't particularly transparent about this.
EDIT: Actually, it works! Wasn't the files, it was the UI with SoundSource. Using the "generic UI" fixed the issue (just in case there are any other SoundSource users out there having any issues).
if you do a
> which pip3
you should get
then
should work.
I know it is an old topic... but as I was spending 1-2hours the last weekends typing eq data... Tried all here explained and still get:
zsh: no matches found: [. /Users/username/Documents/rew/filename.txt]
as an error message.
Basically I have no clue how to use python and git and just follow this instructions from this old posts on my new mac os sonoma.
Any help would be highly appreciated
I am building a small app running in the browser so you have nothing to install. Coming soon...
