Al and Cu (no one would use silver or gold) have the permeability of air, Almost air core. Placing high conductivity materials between the magnet will realize and induction heater. That heat(er) will encourage the failure mode of thermal demag. Then there will be the high electromagnetic drag. So now I understand why the Qms was identified as, Qms < 1, ouch! I was taught by a EM scientist from MIT in 1995 to minimize mechanical losses, moving coil audio transducer efficiency is already very low, ~1% efficient. Transducer engineers have design rules. Is that an inventive step anyway? Yes a step backwards. At best it's a claimed improvement to Almost air core but I claim it is not an improvement and it introduces a potential failure mode and reduces efficiency.
I am quite surprised that you, after having worked with transducer design for so many years, seems to have no clue how shorting rings work, or even loss.
Firstly, you do not get high loss by using low resistance shorting rings. Yes, you will induce current, but even if this current is 10A, the copper ring would bave maybe 10mohms of resistance. This translates to 1W peak, and as I am sure you know, the average crest factor is around 8, meaning we are looking at around 0,125W nominal at high levels.
The reason heating in the copper ring may occur is because of the induction between the motor and the surrounding conductive materials. With no copper there, you will generate almost the same amount of current within the magnet rings instead as they are also conductive.
The heat loss in the coil is at a completely different level. If you replace the copper ring with non conductive material, you will lead less heat away from the magnet rings, the coil will dump more heat into the magnet rings, and the overall ability to dispose heat from the motor will go down.
The ring does work as an induction coil. Normally this leads to slightly increased efficiency compared to not using any shorting ring. Not reduced efficiency as you stated.
The resulting Qms typically go up, not down, as you add shorting rings. This is because shorting rings have less resistance and then also less loss than steel and magnets.
Adding a shorting ring does indeed improve this design. The more questionable part is if this is a good design for a woofer to begin with.
Someone posted in this thread that they tested the Borresen transducer and the voice coil reached a temperature of 350 degrees (no unit posted C or F) and the magnet temp only increased 2 or 3 degrees. So if the magnet spacers were Al or Cu then I will assume that Santa Claus or the Tooth Fairy was cooling the magnets!
I guess you refer to my post. As I stated, this was testing done on a 21IPAL from B&C, powered by an 8,5kW amplifier with pressure controlled PID servo. It also uses a real power sensor for RMS limiting. It has a neo motor, 48mm winding height and 18mm gap. It was mounted in a 30Hz horn cabinet for the test. The driver was flipped with the magnet out for the test to give better access to the motor.
I used contact thermometers in 3 different locations on the motor. I also used a thermal camera monitoring the voice coil through some gaps. The temperature changes rather quickly, but I recorded in excess of 350 degrees celcius during the test. After about 30 minutes of testing we recorded an increase in temperature of between 2 and 3K on the motor. The readings were stable across all three sensor locations.
Neither Santa Claus or the Tooth Fairy was present at the time, but two other engineers from two different companies were present.
1. Steve Mowry
2. Guy Lemarquand et al.
3. Mathias Rémy
4. Michael Borresen
The list is short to say the least. Can anyone find any additional work on this topic? I am still interested in this topic and it would have the potential to add information to this thread.
You can safely add me to the list as well, but I know I am not the only one.
A healthy discussion around ironless motors will not take place in this thread as it focuses on your anger towards Børresen for several pages. You should start a new thread without any of that.
PS. What do we want between the magnets if not Al or Cu? Ideally we want air!
That is like stating that demodulation rings do not work.
