mightycicadalord
- Joined
- Nov 10, 2021
- Messages
- 542
- Likes
- 555
If anyone wants to send me a pair of the gen versions I'll be happy to compare
The problem is they are $8000 for a pair. The value proposition for these larger studio monitors does seem to go down rather quickly. I don't see why something with similar performance couldn't be achieved for around 1/10 to 1/8 the price. Either a diamond in the rough among PA speakers or a DIY build.
I didn't say the same though, I said similar. The B2031A has similar performance to the 8030C at about 1/3 the price. We will see the measurement differences when they arrive with Amir. I preferred the Behringer by some margin, others may prefer the 8030C. The value given by the B2031A is much higher though. It doesn't sound "cheaper" than the 8030C to my ears, yet it is far less costly.Buying a pair of active monitors with the same performance as the 8361A for $800? That would be very nice, but highly unlikely.
Edit: You meant the S360, same answer though.
This is the part I don't understand. If FR distortion is linear and isn't too egregious, then it can be corrected with DSP. You can't correct a lack of SPL or sense of size though.they say QSC is good value in PA. this is a 3-way with 15" woofer and compression driver https://www.sweetwater.com/store/detail/KW153--qsc-kw153-1000w-15-inch-3-way-powered-speaker
I have been saying that there are probably dozens of gems between PA solutions. especialy for us who will use EQ anyways. we are paying extra money for frequency response focus while not needing it
They are 10" + coax though, not 10" + CD. The ones getting high praise seem to be 10" + CD. I've not heard anyone describe them as mud, quite to opposite (might have too much highs, fixable with EQ?).I’ll admit I haven’t dabbled much with PA gear, but I do have a pair of JBL Control 30’s in my shop. They’re passive with a 10” woofer and a coaxial mid/tweeter. I think around $1400USD/pair. They sound pretty good in my shop, but compared to my 1032’s they sound like mud.
There you go…a completely meaningless comparison! Lol
Next step with a commercial product is probably a used pair of Genelec 1032s. Not for 1k, though. Even a DIY effort won’t bring you there with 1k.You could be completely right, I don't know. I'm just trying to see what the next step would be.
I really don't know. I want to avoid spending $5000 if there is another way to achieve the same goal, if $1000 will get you 90% of the way.
You could be completely right, I don't know. I'm just trying to see what the next step would be, if you want more SPL/dynamics, the next step above is a probably a KH310, which is around $5000 for a pair. Can nothing be done that is 90% as good at 1/4 the price. Maybe just pulling the Behringer drivers out, putting in a floorstanding cabinet and adding 10" or 12" driver for 150hz down, would this work?
Would be interested to see them on Amirs oder Erins NFS as they have interesting specs for their priceI’ll admit I haven’t dabbled much with PA gear, but I do have a pair of JBL Control 30’s in my shop. They’re passive with a 10” woofer and a coaxial mid/tweeter. I think around $1400USD/pair. They sound pretty good in my shop, but compared to my 1032’s they sound like mud.
I have to say I am intrigued by the idea of a high efficiency 10" + CD though. I think the 1032 would definitely be an improvement, but might be something of a sidestep, where a high efficiency design would definitely have the resources for high SPL. My memories of PA speakers is not good though.Next step with a commercial product is probably a used pair of Genelec 1032s. Not for 1k, though. Even a DIY effort won’t bring you there with 1k.
Funny, because I’ve actually got a single control 30 I could send him…he wouldn’t even have to return it! LolWould be interested to see them on Amirs oder Erins NFS as they have interesting specs for their price
Source: https://jblpro.com/en-US/site_elements/control-30-spec-sheet
The 1032C is rated at 116 dB SPL and German language listening reviews say that only at higher output levels than your ears can bear, the tweeter begins to distort/loose resolution. They get loud clean. If you can find a good used deal, they will be light years ahead of cheap Mackie PAs. The Mackies, they are plastic enclosure (probably resonant), entry level 10-inch PA tops, rolling off even a bit early for sub integration. Well you can order one speaker if you have measuring abilities and an equalizing chain ready and see how far this brings you. I wouldn't waste the time.I have to say I am intrigued by the idea of a high efficiency 10" + CD though. I think the 1032 would definitely be an improvement, but might be something of a sidestep, where a high efficiency design would definitely have the resources for high SPL. My memories of PA speakers is not good though.
Have you seen the Mackie C200, what do you think about that speaker (obviously would need a sub).
I think that large speakers just don't sell. Since 1970s, as power started to become cheap, amplifier watts have grown and speakers got smaller, but it isn't a like for like exchange. Smaller speakers (even if more accurate) seem to lose something compared to larger, more efficient speakers.Simply using a larger driver is one of the better solutions, overall. It seems to me that the audio experts have been conspicuously silent on the topic, or maybe they are just tired of answering the question. I tried to start my own thread to flesh out the discussion, but it gained little traction.
That seems a fair assessment. I don't have the equipment to measure and EQ properly, which is a fair amount of extra cost in itself, then comes the learning and applying that knowledge. I think you are right about the Genelecs being far less hassle, at least in the short term.The 1032C is rated at 116 dB SPL and German language listening reviews say that only at higher output levels than your ears can bear, the tweeter begins to distort/loose resolution. They get loud clean. If you can find a good used deal, they will be light years ahead of cheap Mackie PAs. The Mackies, they are plastic enclosure (probably resonant), entry level 10-inch PA tops, rolling off even a bit early for sub integration. Well you can order one speaker if you have measuring abilities and an equalizing chain ready and see how far this brings you. I wouldn't waste the time.
