Hello,
I have recently purchases a set of DCA Noire headphones, and while the headband is comfortable, the two-wire design can resonate for a long time even at the lightest touch, adding noise to the listening experience. Therefore, I designed a brace part to stop the headband wires from resonating. With my testing, this design works well and stops the resonance effectively.
wire brace render
After installation on headband. Design works effectively. The brace stays in place with friction and doesn't fall out with regular stretch and twist of the headband. No glue is needed, and the mod is perfectly reversiable.
Are you all experiencing the same problem? What do you all think about this design? Let me know if you want to try this mod as well, and I can share my 3D model.
wire brace render
