Mieczyslaw1977
Hello everyone,
The original post as well as detailed review & measurements of Yamaha's A-S701/801 integrated amplifiers can be found here:
YAMAHA A-S701 - tear-down, thoughts about the internals & few measurements
I've been using the Yamaha A-S801 integrated amp as a heart of my audio system for a couple of years. Thanks to the above thread, as well as detailed description and measurements by TRL, I know it is well worth the money that I had paid for it in the past. The A-S801 used to be a part of a budget stereo set, together with Yamaha CD-S700 (very decent for its price) and Castle Knight 2 monitors.
In the meantime I've literally changed everything: I've got Jay's Audio CDT2 MK3 as a CD transport, paired with Topping D70S MQA DAC (thanks a lot for your measurements!). I also bought new speakers - Gato Audio FM-30 floor-standers (50-250 W, 4 Ohm).
I am still very pleased with my A-S801, however I've been thinking of an upgrade for months ( audiophilia nervosa )
Considering everything which has been written and reported in that thread about A-S701, which can be applied to my A-S801 too, what would you consider as an upgrade in the range between equivalent of 2000-3000 $?
I'm not talking about the "sound", as I know it isn't the right place to talk about such things, but about build quality, engineering, internal build and measurements above all.
I'm a bit old fashioned kind of guy, so I would stick to class AB integrated amps with linear power supplies. Separated (pre amp + power amp) are not excluded, however this would mean more cables (mains power cable, interconnects etc.), and I don't think the Topping D70S MQA would be good enough as a preamp.
The new A-S1200 and A-S2200 have weaker power amps sections. I'm not willing to pay 3/4/5 times more for a weaker amp, no matter how much I like the external design, drooling to the VU meters (rather small in these cases).
https://usa.yamaha.com/products/audio_visual/hifi_components/a-s801/specs.html
https://usa.yamaha.com/products/audio_visual/hifi_components/a-s2200/specs.html#product-tabs
Classic integrated amps like Yamaha A-S3200 or Luxman LX-507 Mark II are far out of my budget/range...
I'm considering Rotel RA-1572 MK II, that has some good reviews, as well it has been rather detailed measured here:
Rotel RA-1572MKII Integrated Amplifier-DAC Measurements
It is a bit stronger in the power amp section than A-S701/801, however other measurements are similar to those taken by Audioholics.
Yamaha A-S801 Integrated Amplifier Measurements and Analysis
(I know it's been posted here several times, but just for direct comparison).
Another option is the much stronger Rotel RA-1592 MK II.
The review is in Polish and measurements are pretty basic, however it seems to be a beefy and healthy integrated amp.
https://audio.com.pl/testy/stereo/wzmacniacze-stereo/3433-rotel-ra-1592-mkii
I would be very much obliged for your comments, opinions, tips (whatever). As I wrote above, I'm still happy with my A-S801, however I don't believe that there are no reasonable upgrades within the above given price tags.
Best regards,
Mieczyslaw
PS. My current happy audio family.
Best regards,
Mieczyslaw
