somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 3,755
- Likes
- 3,055
@thefsb What ALSA EQ things have you tried, and in what way were they unsatisfactory?
Volumio has plugins that can do EQ. I'm most familiar with the brutefir one that's out of tree and needs installing via ssh, but the parametric and 'simple' 10 band graphic eq plugins are core ones that should be available via the GUI. All actually work by setting up alsa using plugins or passing through an external program (BruteFIR).
The alsa 'equal' plugin is more versatile than it's usually given credit for - it's actually a generic wrapper for LADSPA plugins, and creates alsa mixer controls to adjust them, unlike the more basic alsa ladspa plugin. If whatever front end you're using doesn't have a mixer gui you can try amixer-webui
MPD can be configured with multiple output devices and lets you switch between them. This example uses that to easily switch between unaltered, crossfeed, eq, and eq + crossfeed alsa configurations.
