Okay. Noted.Disagree regarding WiFi dongle for RPi4. Onboard WiFi with metal case was poor for me. WiFi dongle much better.
https://www.martinrowan.co.uk/2019/08/wifi-signal-strength-with-raspberry-pi-4-cases/
First post. I can't tell you how happy I am to have found this thread/forum –– I've been wanting to set up a Rasberry Pi streamer and ended up discouraged by the audiophile videos on youtube instructing that the DigiOne Signature Hat and expensive power sources were necessary for quality sound. The bill runs up quick and gets into the range of the lower end commercial streaming boxes, which seem unnecessarily expensive for what they do. This is exactly what I want. I'm ready to order, maybe today.
I'm hoping some of you with knowledge and experience will answer a few questions and keep me out of trouble. I have never seen a Rpi, and I'm not an IT guy, although I have experience with computers (Macs, design/photography) and making stuff (built my 2A3 amp from a Bottlehead kit). I will be connecting to a Denafrips Aries II DAC, which does have a USB input.
I want a straightforward network streamer (wifi/bluetooth) that can stream Tidal (or other services), internet radio, and access a USB drive for ripped CDs and downloads. If I can access the USB drive through the device that would be great, but not a deal breaker if I have to move it to the computer to add files. I'm not opposed to a NAS but if it adds much expense and complexity I'd be fine with a USB . My router is in another room, so I'd prefer to use wifi to connect vs. ethernet. I want a good, smooth interface via iOS app. Volumio has gone subscription, which I don't like, but will tolerate if there aren't better [quality] alternatives.
I'm thinking I should get the Rpi 4 because of the isolated USB ports. I know some say that it doesn't matter, but I think the cleaner signal is worth the cost, plus more robust all around. Do I need to add something to make it work with wifi or is that built in?
Rpi 4
Heat sink case (brand, model?)
wifi dongle (or not)
micro SD card (16GB?)
500GB or 1TB USB drive (brand?)
Power supply with extra umph (brand?)
Software (Volumio, free, or pay once alternative)
Am I missing anything? Thanks for any insights, suggestions, corrections!
To get respectable bootup speed and since I'm buying new, which version should I buy? is 2gb internal memory enough?
That was TheWalkman who said that.but m8o says he's using several Zero W models
Does it really matter to have the independent USB ( RPI 4b? )? Is there any difference in sound ? I doubt so?That was TheWalkman who said that.
All mine are 3B, 3B+, 4B+, and one Nano Pi NEO2.
It depends - issue #2215 is real, but whether it occurs depends on what software you're running among other things. I've never encountered it with piCorePlayer, and with Volumio it was only after installing the BruteFIR plugin for example. I'd generally recommend the Pi 4 to avoid the possibility of this issue since the price difference is small, but if you know it won't be a problem there's no reason not to use a lower model.Does it really matter to have the independent ? Is there any difference in sound ? I doubt so?
If you are using the RPi only as a player, 2GB should be fine. If running a server on it, I'd suggest 4GB.btw 2gb RAM is good enough rite?
I'm not aware of a server even needing the full 2GB, let alone 4GB. LMS certainly doesn't need that much. The biggest user of memory is probably the embedded web browser that sometimes gets used to provide the local interface. I've seen reports recently that the 2GB models are getting hard to find in some parts of the world though.If you are using the RPi only as a player, 2GB should be fine. If running a server on it, I'd suggest 4GB.
I will not claim to hear an audible difference from the output of a 3b to a 4b+. But maybe it's because I use well engineered HAT DACs, rarely USB out to a DAC, so didn't experience what others have? I don't have experience with other RPi types so will go by their assertions.Does it really matter to have the independent USB ( RPI 4b? )? Is there any difference in sound ? I doubt so?
And finally I don't only stream music. I make NAS SAMBA servers, Kodi servers, and small low power always on servers for various tasks, for myself and friends.
Volumio would meet your needs without a paid subscription-its pretty basic in terms of configurability but connects well to a range of sources and has a nice ui Moode audio is another option. I’ve used both extensively and prefer moode. It is arguably less prone to sudden breakage on updating and is more configurable from an audio standpoint, it has really good eq which is due a significant upgrade in 7.1.Would you be so kind as to recommend a few software options, and the main distinctions between them? I think Volumio looks good, but I am not inclined to pay a monthly fee to access another service that also charges a monthly fee (a reasonable one-time fee, no problem). What I want is an indexed drive with my ripped files that I can search easily by tags or metadata, and which has a smooth interface and displays album art. On the streaming side I’m probably good using the service’s interface and streaming via AirPlay. I am currently doing that through my Roku TV and it sounds great. My DAC recognizes the high rez stream. A tablet may be in my future once I get everything else set up. What are your thoughts? (thank you)
My understanding was that you were good with airplay and local files. If you want to use volumio with tidal or qobuz natively you will need a sub, but you can use tidal/qobuz at 192/24 over upnp on the free version using mconnect or similar. On moode you would need to use mconnect again over upnp for tidal or qobuz for 192/24. Either will do 44.1/16 over AirPlay direct from the tidal/qobuz phone app. They both use mpd which is compiled with support for most common codecs. Last time I checked Apple don’t support flac natively on their devices, but it’s easy to install software such as VLC that does.Do they not require a subscription to stream high rez like Tidal and Qobuz?
I may give Moode a shot then- sounds great if it indexes the local files smoothly.
What about file formats? Is everyone using flac? My understanding is that Apple devices still do not recognize it.
Glad Phorize is either in or closer to your time-zone or wakes up way earlier than me, lol. Go by everything said.Would you be so kind as to recommend a few software options
Ok my primary purpose is spotify or tidal for now . I might consider ripping my flacs town ssd will I be able to attach to the rpi? What software should I use . Do I need special adaptor for added ssd load ? ThanksVolumio would meet your needs without a paid subscription-its pretty basic in terms of configurability but connects well to a range of sources and has a nice ui Moode audio is another option. I’ve used both extensively and prefer moode. It is arguably less prone to sudden breakage on updating and is more configurable from an audio standpoint, it has really good eq which is due a significant upgrade in 7.1.
You may want to consider contributing something to any project you use. I pay a monthly donation to moode. There may be other options but others may wish to comment on those.
So many options...Ok my primary purpose is spotify or tidal for now . I might consider ripping my flacs town ssd will I be able to attach to the rpi? What software should I use . Do I need special adaptor for added ssd load ? Thanks
