A Pneumatic Loudspeaker Experiment Traveling Through Time: How Would You Measure It?
Same 2" driver, 1.5V, 1cm, green=DZ, red=sealed, 0.35L
He's already had 2 threads at DIYaudio where he is up against this kind of group of responses where the posting member masses have told him he is incorrect and there is nothing new in his "new alignment" endeavor.
General consensus is this is a dual chamber 2 port DBR, opposed to a 3 port DCR, and is tuned low enough to not be of benefit over a sealed alignment. F3/6/10 on his measurements show 110/100/90 Hz. His claims of reasonable output at 20 Hz is 36dB down from reference and not really usable.
ASR and diyAudio — many of the same people, although not everyone uses the same nickname on both forums. I do. I have nothing to hide.
DZ concept was based on suppressing resonance while preserving the fluid-dynamic interaction, rather than using resonance as the operating mechanism.
The objective was NO SOUND from the port. The mufflers/restrictions were introduced to suppress acoustic radiation while retaining the pneumatic interaction inside the system. Of course, resonances cannot be eliminated completely — and trying to eliminate them completely may be pointless if doing so also disrupts the other processes in the system. So the presence of a port, chambers and unavoidable resonances does not by itself establish that the system was designed to operate as a DBR.
Diagram from my diyAudio thread below.
I’m adding comparative measurements taken on the terrace: DZ vs sealed, same driver, 1.5 V, microphone at 40 cm, same 2" driver, free-air Fs = 159.83 Hz.
The terrace introduces reflections, modes and other measurement noise, but these affect both measurements under the same conditions. So the relevant point here is the comparative behaviour, not every small feature in the curves.
Below are the SPL and group-delay plots.
If someone still considers this simply a DBR response, please explain specifically how the DBR model accounts for these measurements. I’m interested in a technical explanation, not just the label.
place A (terrace)
place B (terrace)
DZ
sealed box
SAME overall response SHAPE AS SEALED — just a different level below Fs. Still DBR?
And finally: I’m posting this on several specialized forums because I’m looking for people who aren’t afraid to stick their heads outside the booming, delayed, but years-tested, stable and comfortably familiar resonant box. :)
Ideas, suggestions, and criticism are welcome: www.deltasignum.org
This is taking its natural progression. OP is the only one commenting.
Everybody moved on my friend, the idea doesn't work. I know that pesky physics always gets in the way.
Let me guess youre going to tell me to build it and measure it myself?
He already did :facepalm:
It was a jab at how hes told me to do that around 10 times already.
The diyaudio threads are like watching people engage in some sort shared delusion. Thats why I hate that forum, no matter how dumb your idea, youll always find a few folks who will keep it alive. You end up with several pages of discussion that gives the impression that some sort of work is being done and the idea has some validity. In reality its just pages on pages of nonsense.
shared delusion
An illusion remains an illusion, whether it is blind belief or blind denial. When graphs don't fit the frame, ignoring them is not skepticism, it's fear of leaving the illusion.
My 2" measurement shows no Group Delay and no resonant peaks. Efficiency is higher than BR. If this is delusion, where should GD appear?
