DeltaSignum
- Joined
- Sep 4, 2026
- Messages
- 39
- Likes
- 8
- Thread Starter
- #61
Which color curve am I theorizing about? Same conditions, same speaker, same input.exactly what you do![]()
Without meas instruments it is the way it is. Either find a lab which has the meas ability or invest into the needed gear when your theory is so worthy for you. I mean that you may get a lot of answers regarding meas instruments here and of course in the wide internet. The pros are here around.Thanks for the answers. I came here asking how to measure this system properly. Trying to fit it into a sealed-box model, and treating differences from that expectation as measurement errors, is rather the opposite of what I was asking for.
The post above has a simplified graph with fewer measurements to avoid confusion. All measurement conditions are the same, the only change is sealed box vs pneumatic configuration. The higher system sensitivity should come from using the second side of the diaphragm through the pneumatic system.
The measurements speak for themselves. Unfortunately, with my current equipment I cannot properly measure the complete system response.
No need for investing, the OP theory is wrong. I read more diligently his GitHub project - it is a simple DBR (Double Bass Reflex) tuned uselessly low, described wrongly by OP as a pneumatic engine. A no go.invest into the needed gear when your theory is so worthy for you.
Look very similar to George Augspurger's DCR
DCR is superficially similar, but DBR (Double Bass Reflex) is different and an older design.Look very similar to George Augspurger's DCR (double chamber reflex) concept. Main difference is Augspurger's concept had a port in the first chamber.
it is a simple DBR
Measured frequency response of your loudspeaker is typical for a 2" loudspeaker in sealed box.
Both.Which Vladimir is correct?
Can you substantiate your claims and comment on post #65?Any DBR, or any plain-vanilla bass-reflex box
nicely arrogant, good way to keep it running for sometime, but the truth will come out anyway..You need to gain a much deeper understanding of the theory, practice, and measurement of loudspeakers, than your present knowledge. I gave you enough information; you are on your own now. And I don't like your tone - you are on the ignore list now.
And 'the truth' would condensate to what endpoint?nicely arrogant, good way to keep it running for sometime, but the truth will come out anyway..
I will just wait for nowAnd 'the truth' would condensate to what endpoint?
Just curious....
JBL and other companies have optimized loudspeakers for their design goals, production methods and market requirements. That does not mean every possible acoustic architecture has already been explored.An Internet rando discovering something that has eluded legendary speaker designers and R&D-intensive, PhD-staffed, patent-rich corporations like JBL for 80 years.
Hey, even blind pigs find truffles sometimes. But mostly, they don't.
@DeltaSignum there's really only one way to settle this: pack your speakers and send them to ASR - you know, Audio Science Review - and let experts do what they do. What do you have to lose?
