terryforsythe
Why? Higher SPL? The front baffle would have to be widened to fit it.Yes if KEF goes for an update on LS60 I would hope for a larger midrange/tweet driver closer to blades size
Higher spl with lower distortion and lower imd , not that I crave extreme levels ( and also the tweeter in ls60 is slightly smaller too ).Why? Higher SPL? The front baffle would have to be widened to fit it.
I am not sure if I remember correctly but I think KEFs lead engineer said here a while back that they have to conduct more research on cardioid behaviour and aren’t sure yet if cardioid behaviour is beneficial for their designs.
That's oddly unspecific. Well, I guess once more manufacturers go that route, eventually they'll have to tag along or get left behind.
KEF doesn’t seem to be the company that just slaps the next trendy feature onto their designs, so I guess they want to truly understand it first and also figure out the best way to implement in their designs.
But if I remember correctly he also said that they are not sure yet if cardioid is even desirable. Maybe they wonder if there is a inherent value of the presentation a more Omni radiating pattern at lower frequencies gives.
I wish I could find the post.
To add to your point: due to the narrow front baffle their non blade/4 bass drivers designs are already struggling to achieve bass output that matches the rest of the performance, so incorporating cardioid behaviour might add additional challenges in this area.If I understand correctly there's also the question of balancing the improved dispersion of cardioid with the reduced bass distortion of non-cardioid. My impression is that a decent number of members here feel that trade-off isn't even close and the matter is well-settled in favor of cardioid, but if KEF's engineers and designers might not necessarily agree, particularly when one takes the added cost and complexity of cardioid.
The total width of the LS60 is 131mm (I just measured it). I don't know what is the thickness of the walls, but they are fairly stout. I'm guessing at least 16mm. If that is a good approximation, the largest mounting hole that will work well is around 100mm, which is the size of the current driver. And, with the plastic trim ring, which I suspect is used not only for aesthetics, but also to reduce diffraction, there just isn't enough width to fit a larger driver with the current cabinet design.Higher spl with lower distortion and lower imd , not that I crave extreme levels ( and also the tweeter in ls60 is slightly smaller too ).
But if something going to improve that’s one thing.
Yes the box has to change to a more rounded front , they get away with the square design because it’s so narrow ? According to their white paper .
Maybe KEF engineers can work some magic within the current size constraints![]()
I agree, I found that interesting as well. It appears to me that the look was substantially influenced by trying to minimize diffraction. It doesn't do it for me aesthetically, but from an engineering perspective it is brilliant.- the look is more about art than conservative hi-fi aesthetics
I don't understand why they put in the dip at 6k. Everything else looks good, but that's bound to hollow out treble reproduction. Ultimately, I think I would still prefer my A6b's to either the Luxe's or the LS 60's.I really don’t get the whole ,,this is an edgy art design“ many people express. Except maybe the back (and even there the ,,fins“ extend surface area to help with heat dissipation) this speaker seems like a form follow function design to me. I doubt you would get that great dispersion with any other form for this speaker. View attachment 564180
If you look at the DI it also dips at 6K and you can see a little flare / widening in the polars, so they presumably put in the on-axis dip to keep the power response / ER response smooth. It appears to have worked.I don't understand why they put in the dip at 6k.
I’m thinking of buying a pair of LS-Luxes for my living room, mostly because of the high praise they have received (though I plan to audition them first), and partly because they I think they’ll fit in with the aesthetic of the room. Unfortunately, the “matching” stands wreck that aesthetic. Can anyone recommend stands that will work with the LS Luxes and aren’t as bulky looking and whose color is white or even better, Dark Titanium?This is a long thread, but does anyone actually own these? Looks like @Jukebox does? And @Redogfizbal returned his pair. Anyone else?
I ordered a pair in Dusk Titanium. We just moved into a house that we'll furnish from scratch. There's no good place to put big floor-standers or even speakers on stands, but there's a modest library with a good shelf for small speakers with about a foot of space behind them. I'm testing with the KEF LSX II LT right now.
I planned to get the Mesavonic CDM65 for this space. But when the LS Luxe came out, the aesthetics were so far beyond the CDM65 (and pretty much everything else) that I changed my plans. I know the CDM65 is excellent -- lots of data to support that -- but there's scant evidence about the LS Luxe yet. Most youtube videos seem to be more marketing than review. Not too many reports from people who have actually done extensive listening.
My take on the negative comments in this thread:
- Room correction or parametric eq would have been nice, but you can just feed it with a Wiim Mini or whatever. I've experimented with room correction for 24 years, and I've had mixed results so it's hard for me to lose sleep over it. I'll try KEF's basic compensation modes first and go from there.
- I think the industrial design is great. The shape is interesting, like a spline surface (reminds me of my days at Pixar). The Dusk Titanium color will integrate into our warm color palette much better than the ubiquitous neutral grayscale or cold silver. I usually don't favor gloss finishes, but in this color and on the curved surface it looks great.
