A new Kef speaker? The Kef LS Luxe
An upgraded LS60 would probably be the size of the reference series but with a similar layout, maybe just the mid/tweet from the luxe still with 4x 6.5"+ woofer per side, VECO, and so basically the LS60 with higher SPL capability in the mids and bass and probably a few Hz lower bass extension. So I could imagine a worthwhile upgrade but it's hard to see it being such at the same size.
I suspect that if KEF upgrades the LS60, they will keep basically the same driver sizes (four 130mm woofers per speaker) and upgrade the woofers to be VECO. I'm not sure whether they would upgrade the midrange to be VECO, though. Maybe. Still, it would be quite a bit more expensive than the LS60, perhaps $10k or more.
If they add larger woofers, I think it would be a bigger brother to the LS60 and, based on what KEF charges for the Reference 5 Meta and the Blade 2 Meta, probably priced closer to $20k.
If it were up to me, the LS70 will use the same Uni-Q as the Luxe, which would necessitate a wider cabinet, increasing overall volume. Throw in VECO, and use woofers from the Blade or Blade 2, and you'd have a full-range monster. $20K sounds about right, but of course this will be a few years away. Maybe THEN KEF will finally pull the trigger on real room correction...
The LS Luxe's Uni-Q comprises a 165mm (6.5") woofer.
The LS60's Uni-Q comprises a 100mm (4") midrange, which I think sounds fantastic. A woofer is not required because it is crossed over somewhere around 340Hz.
The advantage of the midrange is that it doesn't need the excursion of a woofer, and thus uses a much smaller surround which, theoretically, should result in lower diffraction of the tweeter signal. Also, the smaller diameter should move the diffraction that does occur a bit higher in frequency. At least for me, the higher in frequency, the less prone I am to notice it. The LS60's diffraction is centered between 9kHz-10kHz. I haven't seen a frequency response plot of the LS Luxe (if it is in this thread I missed it), but I think it will be lower in frequency. EDIT: The diffraction causing the dip between 9kHz-10kHz is due to the tweeter/midrange interface. The surround would cause a dip around 3.7kHz - 4.5kHz, but the frequency response is pretty clean in that area, likely helped by the small surround and the plastic trim around the driver.
As a side note, the Blade uses a 125mm (5") midrange. I haven't heard it, but based on the data I have seen, it performs fantastic.
It's battery-powered, I hope?..
Eh? Why? Power outlets are pretty ubiquitous so needing to plug in isn't a big limiting factor. Obviously not needing a plug would be even cleaner, but I don't think shoving batteries into these speakers is terribly practical. These are a far cry from the tiny battery-powered speakers you can detach from some higher-end sound bars.
I just imagined how the household staff could replace the batteries while the owners were in other rooms. Perhaps I need to be more serious.
Hi everyone,
Quick update on my previous post about LS LUXE latency.
After around 1.5 months, KEF finally got back to me after checking with their engineering department.
They measured:
LUXE AUX input → speaker output (Cable Mode): 7.297 ms
I’ll attach their reply/screenshot below.
This is very good news for me, as I previously owned Devialet Phantom II, which had around 60 ms minimum latency, making them unusable for DJing with my Pioneer DJM-V10.
KEF had previously told me that the LS50 Wireless II has less than 6 ms total latency, so the LS LUXE figure is very interesting.
I’m now seriously considering the LUXE again for my DJM-V10, projector, AirPlay 2 and KRK S8.4 subwoofer.
Does anyone know if 7.3 ms is low enough for DJ use, and whether this measurement represents true end-to-end latency?
Thanks!
What KEF measured is true end-to-end, and yes, that's good enough for DJ use.
For even lower latency, consider feeding the Luxe from your DJM-V10's AES-EBU output via a Neutrik NADITBNC-F or NADITBNC-FX.
This removes one DA conversion and one AD conversion from the signal chain.
Won't allow you to use their sound bar as a center channel though, so I'm not sure exactly what form this will look like when ever it's released.
Not all of us want to use a sound bar as a center channel, though.
True. My point was I don't think you will be able to add what ever KEF you want to the set up. I think it's going to be limiting.
Well, I think that if/when KEF introduces multichannel applicability, it will be incorporated into the audio engines of all the available wireless-capable speakers, even if they do not expand the line.
Hopefully you are correct.
Wasn't this the path we were meant to take?
Yes. Pattern control over most of or the entire frequency range should be standard in high end speakers today. If DIYers can achieve that using KEF drivers, KEF itself should too.
(Screenshot taken from video presentation of this speaker)
Yes if KEF goes for an update on LS60 I would hope for a larger midrange/tweet driver closer to blades size
I am not sure if I remember correctly but I think KEFs lead engineer said here a while back that they have to conduct more research on cardioid behaviour and aren’t sure yet if cardioid behaviour is beneficial for their designs.
They also have this driver
A 10 inch 3-way coax
Don't know why they don't use it in a box speaker View attachment 563536View attachment 563537
I think I have read in a white paper the current very narrow front baffle on their box designs helps with horizontal dispersion control/smoothness, so maybe a box Thats wide enough to host a 10 inch driver doesent achieve the dispersion pattern they want.
