A new Kef speaker? The Kef LS Luxe
I didn't realize that Wiim sells a $99 device with room correction, that's amazing.
More generally, this is an issue with putting everything inside the speaker. Active speakers have clear advantages over passive, but putting more than the amps and crossover inside leads to issues with future-proofing.
The DSP also needs to be inside the enclosure; as for the streamer and preamp, well, that really depends on personal preference!
Having a separate box for the preamp and streamer does make it possible to consider an upgrade, but on the other hand, it adds an extra box and cables, which somewhat goes against the concept of "live-style" speakers.
It seems to me, by the way, that manufacturers are pretty split on this—you see both solutions in roughly equal measure (I didn't count them, of course; that's just a rough estimate).
Personally, I'd be more in favor of the all-in-one option.
At worst, if there's a technological revolution in the streaming industry, we can always add a separate device from a third-party manufacturer—like WiiM, which has an all-in-one speaker.
@jackocleebrown or other KEF reps, hopefully since this new 6.5" driver has been invented we can expect a passive version of the LS50 with a larger driver? Or does this require some of the tech from the active version to be feasible?
A speaker like that, with a 16.5 cm UniQ driver, would overlap a bit with the LEF R3 meta.
Obviously, VECO isn't an option in a passive speaker and I wonder—though I'm not at all sure—if the VECO and DSP might be limiting the woofer's excursion to prevent it from interfering with the tweeter.
Well, that's not good.
LOL. And strange...I wish the statement was more descriptive. Is it SPL limited? Is the low end overpowering? Does the upper registry sound recessed? Where is the listening position and how are the speakers situated? Saying they sound like cheap junk (when seated at the listening position) is a massive jump. LOL. No, offense meant.
Well I’m not surprised, but these are fantastic speakers. Very resolving, massive stage. They look even better in person, my wife even said she likes them because they don’t look like speakers. I have the dusk titanium color. There’s a problem though. Because they are sold as a lifestyle speaker with no compromises, I do have to compromise on the software. I need room correction. It’s so bad at my movie watching position that they sound like 15.00 cheap speakers from Walmart. Unless I’m sitting in the perfect position in my room they are basically useless. So do I compromise and purchase a wiim ultra so I can correct for what should already be built into a no compromise speaker system, or should I just return them and buy something like Cabasse offers?
I am not sure if "room corection" can help here.
Try to make wider soundstage, and rotate them perpendicular to front wall.
This way you get nice off-axis response which as stereo might be better also in wide left-right line of listening points - could be allright in direct on-axis to one on each side of triangle, because the sound is summing in stereo.
Also if there is a reflective rear wall behind your sitting spot, that could be problem.
There is no need to put a 5cm or more there, but 2cm of smart damping material is a must for highs.
You will also see big difference in bass when you put pillows in the corners, what may end up with real traps.
Every detail counts...
We can help to find the root cause if you provide a sketch or photo of the room, especially your speaker position and listening spot.
The cause can be many things: missing a center channel for speech in movies, room layout, listening position, speaker position ...
cost-no-object, one-and-done market. A small but good target for high-margin products.
The other is
A market where they buy a lot of different things without counting the money is probably even better, but it is probably(??) very limited.
unabashedly monikered Luxe
Luxury should not look more modest than JBL M2
All Comments​
  1. Comment by JohnHB.​
    just now
    I am impressed how Kef picked up the possible improvements of LS50W2 speakers. But do not understand room correction option is not included, like Sonos, Denon, Klipsch and others have standard now. This is really a missed opportunity to finish this models qualities and a dealbeaker for me considering the price. Hope Kef will realize this soon
As much as I love the Uni-Q driver and the LS50 look, this thing's design is a big pass for me ...
Being in complete agreement with your statement about room correction (and the LS having the capacity to include hardware capable of running Dirac, if not, it should be implemented), my other Rubicon is in the capacity to extend the system to multichannel. Since the current LS series can be connected via RJ45 cable, it could theoretically be possible to connect several speakers to a hub, and that hub to the main speaker.
As for multi-channel capabilities, it is indeed a shame that the LS Luxe isn't WiSA-compatible, even though I get the impression that this standard is struggling to gain traction—or even to develop at all.
For what it’s worth, here is a thread about room correction with the LS60. Imo massively improved sound, but it is not trivial to set everything up so that it works seamlessly with TV (wake up, remote still works etc.). I can’t believe KEF still doesn’t offer it out of the box.
Nice advert indeed.
Nice advert indeed.
Advert for what? The LS60, the BlueSound, Dirac? I am not paid by any of them, and as I said, I don't think I should be forced to jump through endless hoops to get a decent in-room, real-world response from my speakers. I don't care how they "measure" if I can't get great sound IRL. And no, I won't be treating my entire living room, and I don't have a separate living room, as I live in a big city with absurdly high rents.
Maybe I should have looked at cardioid speakers - but then we're talking D&D C8 at 3x the price....
actually even with D&D 8C you just minimize the room effect, there's still some portion of the LF will be omnidirectional, but you can easier EQ the 8C though
So I see you want to live with stereo.
Try to listen in bedroom if it is possible.
Sometime bed can make a miracle as -18dB well treated listening room.
Window reflections damp by curtains.
It is almost no-cost solution, and may can change your life positively.
If it is not possible, then meet some shaman ;)
The thing is, I am very happy with room correction. It makes a massive difference in my room - that's for sure. I could probably get the same (or even better?!) effect if I treated my living room, but it would involve getting curtains, giving up my hardwood floor, etc! All of this is expensive, and I like the way my living room looks right now...
Knowing the difference now, I would not buy a speaker without built-in room correction in 2026. I am happy I could "fix" the LS60 with it, but it took me a LONG time to get the entire signal chain and remotes, etc., working. My next hi-fi step would be cardioid speakers - though I am not sure how much they would improve my in-room experience.
Room correction can’t help with room reverb. Lowering the reverb will also make a great difference.
Cardioid is now available at much more affordable pricing.
Of course cardioida is best in many ways.
Looks like Bose may produce cardioidic HT, and Sonus Faber HE speakers in next 10 years.
Maybe also others will suck in next decade heh...rules.
