HAHAHA..... I think I may have done that too with my old old systems..... before I knew better...Many times when we got a unit back for service all the bands were at maximum gain...
I've noticed the same thing; that said, the KH 150 has a slightly larger internal volume (12.6 L, if I recall correctly), which should give it an edge in the bass.I just realized that 22 L of external volume is roughly the same as an A6B or a KH 150, both of which are considered close to state of the art when it comes to bass extension for that size.
My Ino Audio piP got an internal volume of 11 L iirc and can reach down to 35Hz with it 4" woofer (designed to be close to the wall for some extra boundary gain), so I'm not surprised that KEF can reach low, but of course depends on how close to the wall you place them and how loud you want to play.I just realized that 22 L of external volume is roughly the same as an A6B or a KH 150, both of which are considered close to state of the art when it comes to bass extension for that size.
What was relevant for an LS60 when it was released isn't necessarily relevant today for an LS Luxe.See NTK's post earlier. A company picks and chooses their battles.
A new Kef speaker? The Kef LS Luxe
They also have Spotify connect ? Is it really missing from this new speaker @pthakkar24 It’s literally the first streaming service mentioned on their spec sheet.www.audiosciencereview.com
I believe it’s supposed to work with Roon starting early next year.Is it Roon Ready? Roon has PEQ that could be employed.
Very different design choices to reach the same goal.I just realized that 22 L of external volume is roughly the same as an A6B or a KH 150, both of which are considered close to state of the art when it comes to bass extension for that size.
It’s in a “neat field” that room-mode issues are minimized; at 3 meters, reflections are significant! (In a standard room). Acoustically treating the room is indeed ideal, but in a living room, that’s not necessarily practical (WAF).Hi again to everybody,
talking about farfield...about 3m distance.
I dont think you need something more for clean flat frequency response than what VECO does with DSP and DSP EQ.
And well damped room.
Of course you can use FIR externally.
I prefer room treatment.
Agree on approx ratio, but assume these are external dims right? Wall thickness will massively eat away at usable volume. Would be surprised of LS50WII has 10L of air volume inside. Does anyone know what the cabinet is made from? And wall thicknessLS Luxe : 298 mm x 223 mm x 336 mm = 22 L
LS : 305 x 200 x 311 mm= 20 L
So about 10% difference if you consider how much space it needs, though it looks like the LS Luxe occupies more volume in thatthat bounding box.
AOR report that the internal volume ou the LD50WII was 7L and the one of the LS Luxe 10.6 LAgree on approx ratio, but assume these are external dims right? Wall thickness will massively eat away at usable volume. Would be surprised of LS50WII has 10L of air volume inside. Does anyone know what the cabinet is made from? And wall thickness
"a custom blend of glass fibre-reinforced BMC (BulkMoulded Compound) was developed. This is the samematerial used for the front baffle of the LS50 Meta andWireless II loudspeakers." From the white paper: https://images.salsify.com/image/upload/s--3dv0Hd7p--/myoxbujcbvrsfpjkmrph.pdfAgree on approx ratio, but assume these are external dims right? Wall thickness will massively eat away at usable volume. Would be surprised of LS50WII has 10L of air volume inside. Does anyone know what the cabinet is made from? And wall thickness
I don't know about the LS60, but the LS50WII lets you make SOME adjustment - in the Advanced section of the KEF Connect app you can tell it how far the speakers are from the wall, if they are on stands or not, and also whether the room is Lively, Moderate or Damped. That's pretty much it, and I would be VERY surprised if the LS60 doesn't have those setting options.Room EQ!! One of the biggest missing features on the LS60 in my (and others') opinion. I wonder if this is a KEF Connect feature and they'll backport it, or does this new speaker really have that much more DSP power under the hood?
That's how my turntable (with built-in phono stage) is connected to my LS50WIIs!If you really wanted to, you could
Of course, not all wireless speakers have even an analogue input
I would counter that the average buyer isn't buying 4000 dollar powered KEF speakers either.I am pretty certain the average buyer has no clue what PEQ is. Or how to use it. People on this site and other audio-focused sites are not average buyers. Should KEF have included it? Maybe, but the ROI isn't there.
So we agree that at 3 meters, the reflections are significant .I did it with IIR EQ implemented in the DSP filter biquads (so no EQ modul), in non-symetric space, in small room opened on two sides.
It was clear very soon that treated or dedicated room is neccessary.
It always starts with rear wall.
By my experience there is no chance for critical listening of music in untreated room.
It could be joyful, yes, it depence mostly on acoustic phase of speakers, not peaks and dips n midbass range.
Bass range is well done only when is localizable from both speakers the same time and level.
Then you do not need a "physical" bass, and this one is not moving left-right, nor making other dips.
Thus symmetric room setup is the easy way.
Of course it depends all on how the speaker is radiating the sound, and then somehow nearfield is easier.
One can realize that to enjoy music are headphones better, especially when every small change in living room ( glass of wine, other person ) can destroy the setup.
If speakers are not well made in those criteria, then there is only FIR to change it, with more or less compromise result ( waterfall ).
That is my observation.
No worries, just wait for the LS Luxe SE ... or maybe they will call it the LS Luxe Pro.Sorry, I'm not buying luxe speakers only to have to patch in a cheap workaround that then disables all the built-in connectivity that I paid for.
Do better, KEF.
The reason I own KEF LS50 W2 speakers is precisely because I have significant WAF constraints and so isn’t necessarily keen on adding a"box" . If – though, to be honest, I doubt it – I manage to convince my better half that this is a very good idea, I honestly wouldn’t go for the KEF LS Luxe, as I’d be paying for streaming and connectivity features that I’m going to bypass, in this particular case, I’m going for the Neumann KH 150s and saving at least €1,500.Just look at eq this way: you can make your luxe Kef superdeluxe by adding a Wiim.
(I did the same for my luxe B&O. LOL)
