A new Kef speaker? The Kef LS Luxe
I was just reading the VECO section of the white paper and man this is some impressive stuff, at least for me.
As far as I am able to understand they first of all created a sensor to monitor the voice coil movement which is based on induction rather than power to get rid of the need to incorporate power supply for that sensor. They achieved this by printing a coil on some kind of thin foil which they wrapped around the voice coil which is replacing the former at the same time. However the coil on the foil would than couple with the magnetic field of the voice coil hence they created a very specific pattern of the coil lines on the foil using FEA analysis to avoid the coupling.
I find this utterly fascinating.
I hope you all correct me if I understand some of this stuff wrong.
x=29.8*22.3*33.6/1000
y=30.5*20*31.1/1000
So x is 22.32854, y is 18.971 (not 20), and x/y - 1 = 17.7% (not about 10%).
(I have not checked that your stated LS and LS Luxe dimensions are correct)
And you have thinner wall, no bracing and maybe loosing some volume due to curved form.
But there is the electronics who seem to sit in a separate enclosure in the LS50 Wireless:
If the LS Luxe have an air tight backing plate and no separate enclosure, there is a big volume to be gained.
From what I understand the idea of a monitoring and driver movement correction system is not new but it is quite a challenge to pack the sensor and the power for that sensor into the driver motor system. with VECO they printed the coil lines on a flexible foil which replaces the former on the voice coil and acts as the sensor which is based on inductance, so requires no external power. However the coil on the foil would couple with the magnetic field of the voice coil but thanks to a special winding pattern of the coil lines on the foil they avoided the coupling and thats the key innovation of veco. So to answer your question: yes they mitigated the downsides of such a system.
This stuff is a bit over my head so I hope you all correct me if I get it wrong.
I don’t know where you live but Hisense and especially TCL TVs have become really good and they focus on these sizes. I would even argue the current flagship of TCL, the X11L is better than the Sony flagship in many aspects. It caps out at 98 inch though. Source: I test TVs and have seen it in person. Write me a pm if you want to answer so we don’t sidetrack this thread.
I think you misread me.
I was talking about Sony wireless speakers like the quads and trio for Living room 4.2 / 5.2 set-up not TVs.
Ah I got it, thought you were complaining about the lack of 98/115 inch TVs.
I had the quad and it is excellent. I am a huge fan of Sonys 360 sound mapping. It really created a nice sound field. Was better immersion wise than my current 4.1 Kef system with Dirac.
Thanks @Goldhamster916, that’s spot on! Really nice to hear that you found the whitepaper helpful.
If you’re interested, we did a video with Soundstage last year in which both Jack and I spoke at length about these technical challenges. There is some footage of parts and a small demonstration of the mutual inductance effect using passive inductors.
A bonus fact (as I’m able to say now) the Uni-Q you see in that video is actually one of the first LUXE Uni-Q samples!
Hi @ppierre, that’s exactly right. For LS LUXE, the electronics are mounted directly on the back of the heatsink, which serves the added purpose of sealing the acoustic cavity shut. In LS50W2, the electronics had their own dedicated volume partitioned from the LMF cavity. For comparison, the effective acoustic volume of the LS50W2 is approximately 7L compared to ~10.6L for LS LUXE.
y=30.5*20*31.1/1000
My mistake, I must have copied the wrong number.
I won't buy any active speaker that doesn't allow you to turn bluetooth and wireless signals off. That includes KEF.
I am happy to have understood that right :).
I think I have seen the video you are referring to and immediately thought it would be nice to have a LS 50 Wireless like design with that technology since the midrange and treble for me can, at least in a small room, compete with any other speaker out there. I believe the true point source design and the baffle form is what makes it so great compared to most other designs. Only thing lacking was the bass, so cool to know I was already looking at what I have hoped for in that video :).
Your white papers are a major reason why I have/had multiple Reference speakers at home and why I will probably get a pair of Luxe as well. Apart from being impressed what you guys at KEF come up with time and time again the white papers makes me understand and value the loudspeaker I get and also statisfy my curiosity while learning more about my hobby.
In my mind one of the only ways a Luxe like design could be even better would be to add two side firing LF drivers to combat potential multi tone distortion issues at very high SPL. If you now add cardioid radiation on top it would be the ultimate small room speaker in my opinion. I hope to see such a speaker one day :).
Would you mind answering what KEFs current view on cardioid designs is?
Any response is much appreciated!
What you describe is than either linear increasing or decreasing, not just linear. However you and @thewas can both be right at the same time, since something can be right in a mathematical dimension and still have a different meaning in other context through conventions agreed on by society.
Got It, I was reading the post @thewas linked in his answer.
No built-in room correction, correct?
Sorry, I'm not buying luxe speakers only to have to patch in a cheap workaround that then disables all the built-in connectivity that I paid for.
Do better, KEF.
I don't use Roon.
An intended "plug-and-play" speaker system without room correction in 2026 is just a total non-starter.
The lack of room correction or even just a PEQ is one of the biggest downsides of KEF app.
I'm confused. KEF puts much effort with their speaker designs to address details, but seemingly puts little effort into room correction. The KEF app does include "Wall mode" and "Bass extenion" settings, but they are insufficient at addressing room modes. Given KEF's technical prowess in speaker design, I'm dumfbounded as to why the don't include at least room correction and user specifiable PEQ in the KEF app.
KEF, are you listening to what your customers want? Look at WiiM as an example of a company that continualy improves its software/firmware to improve user experience. Heck, maybe you should consider hiring their engineers as consultants?
I'm basing my perspective on the KEF app for my KEF LS60 speakers. Maybe they improved the app for the LS Luxe, I don't know. If they have, great, but if so that improvement should be made available to owners of their other wireless speakers.
Both my LSXII and LS60 works with ROON.
They also have Spotify connect ? Is it really missing from this new speaker @pthakkar24
I also use them with external streamers WiiM or Squezeboxes so it use both ROON and LMS .
The WiiM provides PEQ for when I use CD or Vinyl but usually streams thet way to for ease of use so tht I don’t have to maintain room EQ in two systems.
Have not tried with tidal connect yet .
I to wish KEF could step up a bit regarding the inbuilt functionality so that it would stay relevant for a while . But the speakers are good enough to not be overlooked even with these deficiencies. It will be like TV’s with built in everything, eventually you get an extra box ;) but not from day 1 ? 10 band PEQ and room EQ anyone ?
Turn of BT and Wifi ? Tin foil hat argument ? The speaker is dependent on a phone or tablet for setup, not even even a functioning possibility.
To bash the inbuilt IT solution some more :) get the web UI fully functional so that all the active KEF speakers can be independent of iOS or android if one wishes to use them solely as active speakers but need to do the basic setup.
I don't use Roon.
Half the price gets you HDMI and Dirac from. Klipsch via the Nines v2.
