solderdude
I extensively compared my own HD800 (with my own EQ which is not equal to Oratory or others) to the Utopia and they were tonally the same.
The Utopia did have a 'metalic shimmer' that I liked at first but after a while realized it wasn't natural and should not be there.
Without EQ I would go for the Utopia as to me the HD800 (without EQ) is bright (with a sharp edge) and thin.
below HD800 vs Utopia
and below the exact same but using smoothing so one can get a better feel of tonal balance differences.
One can say these are both equally 'rolled off in the bass' but it is the lack of elevated treble that makes the Utopia fuller sounding/less bright.
About 6dB less treble is VERY audible. The peaky behavior is what I think is responsible for the metalic 'shimmer' of certain instruments. Not bothering, it even has 'something' but in the end just a tad unnatural.
Comfort on both is great but quite different. HD800 is a bit more 'spacious' as well. Both are about equal in instrument separation/pinpointing/looseness (if those words make sense to me).
Utopia is 'plush' and feels like any normal over ear headphone but is a bit heavy (almost 500 gram)
HD800(S) is lighter in weight and sits very different on the head. May not be everyone's cup of tea but I like the comfort.
Both have a thick and long cable. The HD800 cable is stiff as well, horrible cable and needs replacement (well I changed it). Both HPs use expensive connectors so replacement cables are not cheap.
Later I compared the Utopia to Clear and think they are too close to warrant the price difference. In fact I slightly preferred the Clear as it lacked the 'metalic shimmer' but isn't as 'ethereal' and 'overly detailed' sounding, more natural treble.
below the Elear vs Clear vs Utopia
As can be seen the Utopia has more 'upper treble' and the 'metalic shimmer' I heard probably is the elevation between 6kHz and 10kHz.
The Clear doesn't have that. If you did not like the stock HD800(S) the Clear would be the best choice.
The reason I haven't bought any Focals (and certainly not second hand, nor Utopia) is the reports of drivers failing and warranty issues. They may just be rumours though.
The Clears, to me, are a clear step-up from the Elear which isn't my thing. There is something quite 'off' with it to me. Not bad sounding, just a bit 'off'
To me the K812 sounded pretty good, as did the DT1990, BUT these need EQ or a passive filter (so can be used without any EQ).
Another excellent one is the HE6 but needs decent amplification.
Filters needed and though all are having good bass extension are not basshead cans!
It is the treble emphasis (curable without sacrificing detail but lowering 'hyper detailing') is by far the biggest reason why folks find these headphones on the lean and bright side.
The HE6 is one headphone I thought sounded 'perfect' to me without any EQ but not all folks agree (as with everything in audio). Heavy in weight though, same as Utopia. Very different pads so feel different.
In the end, I always return to the HD800 (with EQ) because it is relatively light-weight, comfortable to me, is spacious, detailed, not sharp (WITH EQ) and effortless and realistic, relaxing.
