- Joined
- Nov 14, 2020
- Messages
- 265
- Likes
- 367
Hi *,
I recently listened to the album "Romantically Helpless" by "Holly Cole" and liked it.
Next I saw that I could buy an HDCD (>$50) in Japan, which might sound better than the 44/16 version offered by Qobuz.
The question arises: Will that be worth the price?
I have some HDCD albums decoded by dBpoweramp to 24Bit so I evaluated quickly what might be the improvement.
The album I picked for evaluation was "Local Hero" by Marc Knopfler.
This is what I did:
- Decoded the original WAV (44/16) with dBpoweramp to 44/24.
- Opened both, the original WAV and the decoded in a wave editor.
Starting with track six "The Rocks and the Thunder" the 16 and 24 bit version were exactly the same but with different volume.
I recognized that this is quite a silent track with all peaks below 0.45 (1.0 equals 0dBFS).
Next I analyzed track tree "Freeway Flyer" and there I found some few differences between the two versions.
* The red signal is the original CD rip (44/16).
* The brown signal is the 24 Bit output of dBpoweramp after a volume increase of 2.5dB to fit both signals as good as possible.
* The light green signal is the difference between both.
We see that the HDCD carries additional information that was suppressed by mastering the 44/16 version.
Results:
* The 44/24 signal created by dBpoweramp HDCD decoding reverts compression done for the 44/16 signal above -0.5 dBFS.
* The 44/24 signal is 2.5dB quieter so you can get a disappointing 0.5 bit higher resolution (which means 16.5 bit) which is far away from advertised 20 Bit for HDCD!
As there is a lot of negative talk in the net regarding the quality of the dbPoweramp's HDCD decoder I also tried with HDCD.exe that can be downloaded here.
This is the result with the same Track:
* The red signal is the original CD rip (44/16) as above.
* The green signal is the 24 Bit output of HDCD.exe after a volume increase of 6dB to fit both signals as good as possible.
* The blue signal is the difference between both.
As you can see, the result is absolutely identical. The only difference is that HDCD.exe lowers the signal by 6dB and you could theoretically gain 1 bit instead of 0.5 bit.
So the answer to my original question is clear to me:
I don't think it's worth paying $50 for the original CD for that half, probably inaudible, bit.
This is what I did:
Results:
