A humble hobbyist's review: Fosi Audio BT20A MAX
_theaudiofile
G’day!
I’ve been a lurker for a while and wanted to start giving back to the community, starting with some thoughts on the Fosi Audio BT20A MAX.
Full disclosure: Fosi sent me this unit to test, but they have zero control over what I publish. This is my unfiltered take.
TL;DR - Over Rating: 8.2/10
The BT20A MAX is a capable Class-D amp featuring PFFB technology, an 80Hz High-Pass Filter, Bluetooth 6.0, and a neutral-warm sound. To push high wattage from a tiny chassis, Fosi utilised an active cooling fan to manage thermals. The faint fan noise and lack of auto-standby make it slightly fiddly for a near-field PC setup, but it performs exceptionally well in a living room environment. It has a few quirks, but the pros easily outweigh the cons and I recommend it.
Design & Setup
The BT20A retains the iconic black and orange Fosi aesthetic. It’s a clean, matte black front panel and a glossy top, contrasted by copper-orange side ventilation grills.
For the first week, I wired it into my bedroom desk setup, feeding it from my PC to drive my SVS Prime Bookshelf speakers using custom Canare 4S11 cables. For the second week, I moved it out to the living room to see how it handled a larger space.
It is important to note what this amp doesn't have: despite the dual RCA inputs, there is no built-in USB DAC or phono stage. My computer's internal DAC handled the Digital-to-Analogue conversion before the signal hit the Fosi. The SVS Primes are revealing monitors that can be bright and demand serious current. To ensure adequate headroom in both setups, I used Fosi's optional 48V/5A power brick.
Music and Movies Performance
The PFFB implementation means the amp delivers a flat, consistent frequency response regardless of the speaker's impedance curve. The overall signature is dynamic and mostly neutral, with a slight lower-midrange warmth that pairs well with the top-end energy of the SVS Primes.
  • Music Test: Starting with George Michael’s Careless Whisper, the amp's soundstage stood out. The iconic saxophone intro cut through with pure clarity without ever sounding piercing, and the lower-mid warmth gave his vocals a smooth texture. Moving on to Journey's Faithfully and Open Arms, I wanted to see how it handled Steve Perry’s vocals. Budget Class-D amps usually make these tracks sound shouty or fatiguing at high volumes, but the Fosi delivered a smooth. Finally, Eagles' Hotel California, the acoustic guitar plucks and intricate instrument layering had excellent separation, and that famous bass drum kick landed with real weight and authority.
  • Movie Test: I loaded up Dune to test pure dynamic range and burst response. The SVS Primes need serious current to deliver cinematic impact, and with the 48V power supply, the Fosi performed. During the flight scenes, the amp maintained a tight grip on the drivers. Switching to Ryan Coogler's Sinners, the amp did a great job rendering the tension-building atmosphere. The sudden dynamic swings and deep, thriller-style bass drops were punchy and fast, never dissolving into a muddy rumble.
Bluetooth 6.0
I am usually critical of wireless audio, but Fosi did a great job here with the Qualcomm QCC3095 chipset.
Streaming FLAC files from my phone via the LDAC codec provided stable wireless performance. The noise floor is low, and the audio fidelity is closely comparable to the wired RCA input.
Range is excellent - I could walk to the kitchen without the signal dropping. Latency is also well-managed, with no noticeable lip-sync delay when watching videos.
Bass Management
A major standout is the 80Hz High-Pass Filter. Flipping the switch stops the amp from sending frequencies below 80Hz to the main speakers, routing them to the subwoofer instead. This allowed the SVS Primes to play louder and cleaner in my 2.1 setup.
Considerations & Areas for Improvement
While the BT20A MAX sounds great, there are some considerations to note.
1. The Active Cooling Fan (A Smart Compromise) Fosi included a fan to manage thermals without bulky heatsinks. While there is a faint hum noticeable from two feet away in a quiet room, it blends in once audio plays. It’s a practical solution, though a moving part always carries a long-term risk of wear.
2. Idle Power and No Standby Mode The amp lacks an auto-standby feature and draws some power when idle. Unless manually switched off, the unit stays fully powered and the fan continues spinning.
Specifications
  • Amplifier Chip: Texas Instruments TPA3255
  • Power Output: 300W x 2 Max (Real-world continuous output into 8 ohms with a 48V supply is closer to 85-100W)
  • Architecture: Class-D with PFFB (Post-Filter Feedback)
  • Connectivity: Dual RCA inputs, Subwoofer Out, Passive Speaker Binding Posts
  • Internal DAC/Phono: None (Purely analogue inputs)
  • Wireless: Bluetooth 6.0 (Qualcomm QCC3095 chipset) with aptX HD, Adaptive, Lossless, and LDAC
  • Bass Management: Switchable 80Hz High-Pass Filter (HPF)
  • Idle Power Draw: ~15W
  • Cooling: Active internal cooling fan
  • THD: < 0.003%
The Verdict & Ratings
Sound Quality: 8.5/10 - Clean, authoritative, and free of typical Class-D load dependency issues. Handles vocals well with a pleasant lower-mid warmth.
Build & Quality: 7.5/10 - The aluminum casing, binding posts, and classic black-and-orange aesthetic feel premium. The active fan is a very smart thermal solution for the size, even if it introduces a moving part.
Features: 9/10 - Dual RCAs, tone bypass, PFFB, stable LDAC Bluetooth, and an 80Hz High-Pass Filter.
Value: 8/10 - Flexible across different setups with a strong power-to-price ratio.Overall
Overall Rating: 8.2/10
Final Thoughts: After two weeks of extensive testing, Fosi built an incredibly capable amplifier with the BT20A MAX. The PFFB technology proves they are listening to the audiophile community. It balances massive power with a small footprint, thanks to the integration of active cooling. If you are using it on a desk, you just have to manage the power switch yourself and not mind a faint fan sound in a completely silent room. However, tucked under a TV for a living room 2.1 system, it drives the setup with impressive authority and clarity.
Hey mate, welcome to ASR. :)
You may need a reviewer tag;
So from all this, are there any actual test results to post, or is this more a functionality and usage "test"?
JSmith
Thanks for the pointer! Just reached out to the mods.
I am not hardcore enough to post measurements and test results, these are from my ears. One day i hope to gear up and get more serious though.
For now this is just a showcase/review, my ears and experiences.
... these are from my ears.
Please read this. It explains why your ears are worthless for passing on reliable information.
I am not hardcore enough to post measurements and test results ...
Instrumental data, in the form of measurements and test results, is "objective", or dispassionate. That means that it is not dependent on the human senses and their attendant emotions. It is therefore reliable for transferring information from one person to another.
Information that is dependent on the human senses is called "subjective", and is usually relegated to the circular file of "opinion". Opinion, in the definition most commonly used here at ASR, is " ... a belief or conclusion held with confidence but not substantiated by positive knowledge or proof." That definition would include voodoo, old wives' tales, and superstition ... but not reliable information.
When it comes to audio, sensory information is gleaned under conditions that are controlled, to isolate the effects of human bias:
The control most frequently alluded to here is "blind" testing. Its particular focus is the effects of sighted listening, an example of cognitive bias. It's not only a way of minimizing the effects of bias and "opinion", but also a way of teaching people what their true capabilities are in relation to the hearing that they so fondly trust and, per the definition above, hold with confidence. It can be humbling, to say the least. ;)
The esteemed owner of this site has provided a video that explains the methods of controlling listening tests, and the reasons why it is required.
That video is part of a collection that may prove valuable to you:
Ok, ignoring words such as "soundstage", "warm" and "smooth", I think this kind of review is a useful and interesting addition to the site. Hard measurements tell me if the signal processing and amplification is competently implemented, but many (most?) amplifiers are better than my hearing anyway so I need other info to guide a purchasing decision. And in that respect, I value observations such as:
But I would still like some input on:
  • was the bluetooth-testing done on iPhone or Android (I guess Andriod, given the mention of LDAC)? Experiences with different models is relevant, especially the user experience, is it easy to connect, any noticeable delays, difference between models, how about from a laptop? I understand that a full-range compatibility test is probably outside the means of a single tester working from home, but as an iPhone-user some actual experience connecting an iPhone to this device would be useful input.
  • how is switching between RCA and bluetooth done? Does this need a remote, or can it be done with the buttons?
  • can it handle switching between bluetooth-devices, or does it need to go through the pairing-process each time? I have experiences with phones "hijacking" the bluetooth-connection (probably: the first phone to complete the handshake wins), how does this work with the fosi?
  • is the fan always running, or does it turn on only when the temperature rises?
I also was sent one by, Fosi, can add info re these Qs:
1. BT works well with my iPhone 16, I have not tested with other devices as that's my daily driver.
2. You can switch between BT and RCA with either the remote or the left most panel button. Using a light press. You press and hold that panel button for a longer time to turn the unit off without the remote.
3. The fan always runs. It activates when the unit is turned on.
4. Have not tested the hijacking thing - this is annoying when it occurs. Sometimes happens to me with my Phone when my wife's Honda pulls in the driveway and it grabs my connection. (The worst offender in this regard I ever encountered was a Logitech BT receiver, it would always grab any BT signal in range and over-ride wherever the signal was previously being sent to.)
Yes, but now listen to a class A amplifier and tell me you still like class D. H wait, never mind. If your happy with class D who am I to tell you to spend your money.
The main benefit of this amp is the dual inputs, Bluetooth, remote. The power doesn’t blow one away, works very well in a small to medium size room. For “just an amp,” my current fave is the latest Aiyima A07 amp. I am fine with class d amps, I hear no difference from my class ab amps and receivers.
Is this the twilight zone, are we still on ASR?
an amplifier with personality, looking forward to some measurements, wondering what pure clarity and lower mid warmth look like.
Joke aside, is it April 1st?
What HPF?
The Fosi Audio BT20A MAX has a built-in 80 Hz high-pass filter (HPF).
The HPF is enabled by switching the HPF switch on the rear panel to ON. You can see it in the photo in the original post that started the thread. The switch is on the right-hand side of the rear panel and is clearly marked.
When enabled, the main speaker outputs filter out frequencies below 80 Hz, providing basic bass management for a 2.1 setup.
So there's no information about the filter order and approximation? Okay, so be it. In the end, whoever needs it and has it can measure it themselves.
Amps don’t have soundstage
Hey Rexroth,
Interested in your comment, I have noticed that many amps that are for sale include terms around soundstage, holographic, instrument separation, voices from behind/in front of speakers, etc.
How much of this verbage is rubbish?
