I’d like to share a recent home experiment we ran, mainly to document the exact setup, equipment used, and listening process.
This is not a claim about altered digital data, and not an attempt to challenge digital audio theory.
It is simply a transparent report of what we tested and what we observed.
This experiment suggests that:
Audio System Used
Source / Streaming- Bluesound Node ICON (used as a network streamer only)
- Vincent SV-237MK integrated amplifier
- Internal DAC of the amplifier used (coaxial S/PDIF input)
- Neat Acoustics SX3i
- No subwoofers connected during the test
Network Setup
Baseline network chain- Fiber internet into the house
- ISP ONT → router
- Router → standard gigabit Ethernet switch
- Switch → streamer (Node ICON)
- Router → existing gigabit Ethernet switch
- Existing switch → DELA S50 network switch
- DELA S50 → streamer (Node ICON)
- The DELA S50 was not connected directly to the router
- It was placed after an existing standard gigabit switch
Cables Used
- Standard Cat6 Ethernet cable (baseline)
- Higher-quality Ethernet cable between DELA S50 and streamer
- Later, two very high-end Ethernet cables were tested sequentially
- Switching from the standard cable to a better one produced a small additional change
- Replacing that with a very expensive cable resulted in a slightly exaggerated bass balance, which was not preferred
Test Conditions
- Same music tracks (well-recorded reference material)
- Same volume level
- Same playback software
- No DSP changes
- Bit-perfect playback confirmed
- Two listeners present
- Configurations were checked by reverting back and forth
Observations (Descriptive Only)
Compared to the baseline setup, inserting the DELA S50 resulted in:- More clearly separated layers in complex recordings
- Slightly improved spatial stability of vocals and some instruments
- Low-level details (decays, ambience) felt more continuous
- No increase in treble sharpness or fatigue
- Bass character remained broadly similar
What This Is Not Claiming
- Digital data did not change
- This is not a “bits are different” argument
- This is not a universal claim
- This is not presented as proof of measurable improvement
Why I’m Posting This
The purpose is documentation, not persuasion.This experiment suggests that:
- Some system-dependent effects, if they exist, may not appear as classic additive noise
- Or the observation may be psychoacoustic or interaction-based
Closing
If others have:- Relevant measurements (J-test, phase noise, time-domain)
- Similar experiments with different results
- Or a clear technical reason why such observations cannot exist even in principle
