kimmosto
- Joined
- Sep 12, 2019
- Messages
- 457
- Likes
- 1,043
'Phase alignment' sounds just phase matching, and mechanical 'time alignment' is not actual time alignment without certain XO slopes or linear phase XO because it does not necessarily produce minimum-phase total. Minimum-phase total is the only actual time-aligned because both excess phase and excess group delay are zero.I find it very helpful to separate the concept of 'time alignment' from 'phase alignment'.
Troels Gravesen uses mechanical time alignment as stepped baffle in many DIY kits to match phase as wide band as possible to enable easy 2nd order crossover without passive all-pass sections. 2nd order IIR textbook XO produces excess group delay too so it's not "actual" time alignment.
