It is audible in room below 1 cycle, done my ABX both with music and signals. Threads exists already about this. But I don't claim its importance or what is preferred since we do not know phase shifts that already are in the mix.I couldn't tell you. That's a great question and it gets complicated. We are in the modal region of the room so if you did Anechoic test would it hold up in a typical room? Are you sealed or a reflex box? Obviously it will be higher at box tuning but how audible at say 25Hz? That would be 40 msec to meet the 1 cycle "rule" depending on how much GD there is in the box and crossover.
When I set up subs I go for a null as it is much easier to hear and measure. Then reverse polarity under the best conditions you might see a 6db rise from mutual coupling more typically 3db. With a null it can go down 10db easy and deeper depending on how close the phase match is through the crossover. I don't worry about the GD as long I get good summation through the crossover.
The other issue is obviously wavelength. At 80 Hz it's 14ft. So with placement are your subs 14ft away or one cycle? I doubt it. That's why a variable phase control is better than simple polarity switch.
Rob![]()
This is very audible for me headphones or speakers in room. Which is a test signal ok, but it works on music as well. 123 Hz saw tooth 1 s followed by the same but all pass 150 Hz Q 0.7
Dropbox
