- Thread Starter
- #41
New. Maybe they need to break in?Did you buy these new or used?
If connected by HDMI eARC check your settings on the TV. No, I doubt they need to break in I was thinking if used you might do factory reset to erase any previous settings, for instance external sub settings.Voices on TV shows etc sound very nasally
No, that's not really a thing beyond the first few minutes and is often done during testing at the factory.Maybe they need to break in?
Damn that’s such a bummer, i was hoping these would be the perfect upgrade and give me the same satisfaction in terms of bass as the Formation Duo’s did… Oh wellNo, that's not really a thing beyond the first few minutes and is often done during testing at the factory.
The LS60s should be able to go below ~38hz pretty well, which suggests you might have a room null there that's being activated more by the LS60s than the Klipsch speakers...
Have you tried a frequency sweep to see if you can hear which frequencies are problematic? I use this a lot, you can run it on your phone via bluetooth if nothing else.Damn that’s such a bummer, i was hoping these would be the perfect upgrade and give me the same satisfaction in terms of bass as the Formation Duo’s did… Oh well
No I haven’t, I can try but tbh they sound great from the mids up, it’s just that the quantity and the amount of hz of bass i’m getting that’s a bummerHave you tried a frequency sweep to see if you can hear which frequencies are problematic? I use this a lot, you can run it on your phone via bluetooth if nothing else.
A functioning LS60 will easily produce audible bass below 40Hz.Damn that’s such a bummer, i was hoping these would be the perfect upgrade and give me the same satisfaction in terms of bass as the Formation Duo’s did… Oh well
Okay I will try. How can I do that with my phone?A functioning LS60 will easily produce audible bass below 40Hz.
Room modes can reduce bass, but only in a very narrow frequency window. They can't cut all bass below e.g. 40Hz.
Try using a frequency generator to sweep from 100Hz downwards.
Once with both LS60s playing, once with just the left one and once with just the right.
If you consistently lose bass at a frequency higher than what the LS60 is capable of, then that would suggest either a setup issue (try a factory reset->User manual), or a fault with the speakers.
Here are some websites that you can open on your phone:Okay I will try. How can I do that with my phone?
You can connect to the speaker with bluetooth and do it that way.Here are some websites that you can open on your phone:
The Ultimate Bass Test | Ultra Low Frequency Range Test
A frequency sweep from 10 Hz up to 200 Hz.www.audiocheck.net
Online Tone Generator - generate pure tones of any frequency
www.szynalski.com
If your phone can't stream browser audio to the LS60, then you may be able to find an App which can do it.
Yeah that'd be a good way to go about it. I could recommend Equilizer APO with the Peace EQ front-end.I don’t think i have the equipment for that i think, maybe i connect my laptop and use a 10 band EQ?
Do both the Klipsch The Fives and the Formation Duo have elevated bass?
View attachment 435125View attachment 435126
My interpretation of this is that the Klipsch, with its characteristic V-shaped (or "smiley") frequency response will perceptually have an elevated bass response. Bass from about 100Hz on down is boosted roughtly 3dB compared to the rest of the frequency range (at least until you get to the elevated treble response). The KEF LS60, by comparison, is much flatter in the bass (and obviously has far superior extension). Perceptually this will probably sound bass shy in comparison. I think a 3dB boost in the bass might get you what you're looking for.
That's assuming, of course, that the LS60 isn't activating a serious room mode due to its superior extension that the Fives and Duo weren't. If so, you still need EQ but you'll need measurements to see where the room mode is occurring to correct it. Or you'll need an automated room EQ like Dirac to do it for you. I think it's worthwhile to invest in a DSP platform of some sort. And a measurement microphone.
Edit: You should definitely be trying what the others suggest, though, to ensure it's not something more basic like messed up settings or a damaged/defective driver.
If you want a subjective bass boost that will get you closer to the Fives I would add a +3-5dB low shelf at 100hz. I don't advise this, but you could also try scooping the mids with a very wide (very low Q) peaking filter at -2dB around 1Khz.I honestly think that’s it, the V shape of the other speakers. Which frequencies can i boost with PEQ to (temporarily and i know not the most accurately) test this? Is maybe a WiiMP a good future purchase?
This is the result (no wall mode, bass extension extra, treble trim +3)LS60’s aren’t bass shy as others have already pointed out. Mine had very useable response below 30Hz in my room. Room mode for me that is/was problematic was ~70Hz in my setup.
OP - I might have missed it but what’s your room layout like? Size? Cubic feet/meter volume. How loud? Do you have some flexibility with speaker placement and or your listening position? First things first, before messing with settings is playing with optimizing your set up if possible. Still sound like something weird going or you’re sitting in some hell of a spot for cancellation.
Measuring would tell more…
I'm going to mostly disregard the high frequencies because it's from an iPhone, but you've definitely got some room modes going on here, looks like maybe a null down near 20hz, big peak around 32, null around 64, and more. These tend to really throw off the bass you hear, unsurprisingly.k
This is the result (no wall mode, bass extension extra, treble trim +3)View attachment 435140
The sweep was pretty loud and i could definitely hear more low frequencies now, so i truly think i need to do a slight V shape EQ, to maybe get satisfying bass at my listening level and to make it more comparable with the Fives/Duo’s.
The speakers are in a 35m2 rectangle room. Sadly i don’t have much flexibility in terms of
placement because of the layout of the room and the seating area in it.
Im such a beginner this sounds so complicated, I don’t even know wat PEACE is and which peaks/which frequencies I need to pull down or up.I'm going to mostly disregard the high frequencies because it's from an iPhone, but you've definitely got some room modes going on here, looks like maybe a null down near 20hz, big peak around 32, null around 64, and more. These tend to really throw off the bass you hear, unsurprisingly.
I might just try pulling the mids down a little with and see how that sounds to you. Also, if you are hooking a laptop up for testing, I would definitely recommend pulling down the peaks you see here using EQAPO / PEACE.
Doing EQ by hand sounds pretty complicated but it can be pretty intuitive once you've done a couple measurements and tweaks. Basically you are adding one filter per peak to lower them, so that the green line becomes smoother and closer to the yellow line.Im such a beginner this sounds so complicated, I don’t even know wat PEACE is and which peaks/which frequencies I need to pull down or up.
I might just buy a WiiM and do room correction, although i don’t know how to do that either.
I’m definitely willing to learn and do the work to make these sound perfect tho
