A free tool that reads REW exports and separates what EQ can fix from what it can't (feedback wanted)
Lige
I've built a free web tool that interprets REW measurements, and I'd like this forum to try to break it.
You give it REW's text export (File > Export > Export measurement as text, smoothing off) for one or both speakers, optionally the RT60 export, and the room's dimensions with the speaker and seat positions. It then:
  • predicts the room's axial, tangential and oblique modes up to 300 Hz, and the speaker-boundary nulls from the positions you enter
  • finds the peaks and dips in the measured response and matches each to a likely cause
  • classifies each as EQ-fixable (resonances, broad tonal offsets), partly fixable, or not fixable (boundary cancellations, nulls at the seat, decay, reflection ripple)
  • writes Equalizer APO / REW filter text only for the fixable ones, cuts preferred, boosts capped at 3 dB, with the preamp the boosts need
  • ranks the other fixes by cost: seat, speakers, sub, absorption
  • maps predicted bass evenness across the floor by modal summation, to suggest a seat
The point is the classification. A peak and a dip look alike on a frequency response; with the geometry you can usually tell a resonance from a cancellation, and EQ only helps the first. The test suite asserts that no filter is ever generated for a finding classified as unfixable.
How the model works and where its numbers come from: https://www.rewexplained.space/en/about
Try it with the bundled example room or your own export: https://www.rewexplained.space/en/analyze
Limits I know about:
  • rigid rectangular room; openings, L-shapes and coupled spaces are not modelled, and the report says when the measurement disagrees with the predicted modes
  • the boundary-null prediction uses the simple quarter-wavelength geometry, so the exact frequency at the seat can differ
  • treatment quantities are Sabine estimates from published coefficients, good to a panel or two
It runs entirely in the browser and the measurement never leaves your machine. No account, no ads, nothing to buy.
What I'd most like: measurements where the classification is wrong, especially a dip it calls a cancellation that EQ did fix, or a peak it calls a resonance that moved when you moved the speakers. If you post the text export and the room dimensions, I'll work through each one.
Thanks. If you run it on your own room, I'd like to hear where it gets the diagnosis wrong. That's the part I can only improve with other people's measurements.
