Hmm, interesting... I guess if the drivers vary significantly due to manufacturing tolerances they won't get the same excursion per voltage, and so the force doesn't cancel after all? (seems unlikely)I have "force cancelling" subwoofers that I designed myself.
The force cancelling effect does not work. Music with a lot of bass can make these subwoofers go walking. I am not sure what I did wrong!
Also, the force only cancels along one axis, but if they are mounted asymmetrically or the drivers exert other forces on the housing, I guess it could move.
Somewhat related:
It occurred to me that 3D printing a small-ish sealed enclosure and filling the walls with concrete might actually be a reasonable approach for a dual-opposed sub. You can make the interior space spheroid to avoid any kind of panel resonance, make the outside look fancy like a KC62, etc. Whatever CAD can provide.
But it still doesn't seem like a slam dunk in terms of bang-for-buck against (say) a low-tier SVS, after drivers and amps.
Anyone know of 500w plate amps and reasonable drivers to go into a budget implementation of one of these?
I think the material to build the housing for one might cost as little as $30-40, building it *should* be pretty easy, and the finish should end up pretty nice.
But I am not sure if it's really worthwhile...
