A Call For Humor!
I do keep wetting myself and it helps a little, but not much... maybe I should start a little wet t-shirt contest of my own
The wet surface of a (bathing) towel is much larger per m2 than that of typical fabric used for T-shirts. Had 39-40C at night in Budapest if I remember correctly, and it helped. Mind you, the evaporated water should be vented from the room, or fungi&friends will thrive. Another option is to get accustomed to the heat -
BTW, a bunch of trees, a house in white and window blinds are also helpful - right now in my living room, no AC, with 34 °C outside:
That's the problem - I can't air much here, remember it's 41° outside. Didn't drop below 30 either this week - even after midnight. Gladly it's over tomorrow.
Meanwhile, imma keep drinking and eating salty. Stay safe friends!
...get accustomed to the heat
My mother's comment (37 °C at her place, 30 inside) oh well, better this than too cold. She was born in 1937... :cool:
A little trick dealing with such heat would be to wet/moist a bahting towel and cover your torsoe with it. When the heat causes the water/moist to evaporate, it takes heat from the towel and it cools down. Your own personal diy radiator. Hot summer in Budapest just after the iron curtain was lifted and the hotel had no such thing as air condition.
When hiking in heat I wet my T-shirt at every possible water source. Very refreshing for 10 to 15 minutes. Right now with 40 °C outside and 29 °C inside I regularly apply a wet small towel on my body to keep fresh. Still just going outside for a short time makes me dizzy.
Same here. Letting in cool air works only at night between 1:00 and 6:00 (latest), afterwards we shut all windows and blinds. It's 26 °C then.
Luckily, I can fall asleep like a dog - instantly, so I simply set the alarm at 1:00 and 5:00.
