Bleib
- Joined
- May 13, 2021
- Messages
- 4,304
- Likes
- 11,015
That's acceptableWell then , I guess you better come to terms with the fact that John Waters probably won't go home with you and f*ck you.![]()
I was after watching the first 15s!Sorry
They mostly don't
Mission impossible
It's from where she came because she heard the bad sound, obviouslyWhere's the kitchen ... (AI doesn't get it).
Humor Me 062 - Loch Ness Monster Babies - Say What - June 27, 1937 by Johnny El-Rady, on FlickrBottom temp is outside - the balcony, whose door is the only way to air this appartment lollluffda!
I do keep wetting myself and it helps a little, but not much... maybe I should start a little wet t-shirt contest of my ownA little trick dealing with such heat would be to wet/moist a bahting towel and cover your torsoe with it. When the heat causes the water/moist to evaporate, it takes heat from the towel and it cools down. Your own personal diy radiator. Hot summer in Budapest just after the iron curtain was lifted and the hotel had no such thing as air condition.
As long as you don't soil yourself... but water is coolerI do keep wetting myself
