Good point!You should take a look at the mechanism under a Beniamin Miracord changer. I used to go into serious depression if one of those came to my shop for repair.
Best synopsis of punctuation I have yet seen.
While I never had any experience with a BSR810, it had great specs and test reviews, but its cam operated system was supposed to be a nightmare to fix.LoL... I never repaired many Dual turntables because I had bigger fish to fry but when I was first starting out I was given a pretty nice Dual turntable with an auto return failure. I looked at the levers and all the assemblies underneath and was amazed that all this worked. The auto return was not operating and I analyzed that thing for about 25 minutes and determined nothing wrong with the assemblies. I was very perplexed. So my mentor was chuckling away and smiling giggling at the matter. He walked over with a container of liquid silicon of the factory specified heavy thick sticky weight and tells me to put a little glob @ a very specific location and so I did and then he said now try the auto return about 10 times to work that liquid silicone grease over the parts and let the mechanism get sorted out by itself. Just like he said, I kept using the auto return function as it malfunctioned and progressively with each iteration of engaging the auto return it commenced getting better with each attempt. Finally it settled in and voila... It worked perfectly and then customer was a happy clam. I was amazed that such a complicated sophisticated mechanism with such large heavy metal levers would rely on a heavy thick sticky liquid silicone but it works very well when setup properly.
