- Joined
- Dec 12, 2019
- Messages
- 18,104
- Likes
- 41,818
It does appear to be authentic -- as I see no ketchup*.
________________
* or catsup, as the case may be.
Maybe the roadrunner's luck finally ran out.
Are you sure that's not a roadrunner?
Creepy... the "stick" that is wolverining out of her right pinky joint...
Creepy... the "stick" that is wolverining out of her right pinky joint...![]()
Audiophiles celebrate new fiber optic speed record of 402 terabits per second. It will now be possible to run DSD files at a rate high enough it will equal LP in sound quality being almost analog. Further improvements in sound quality will be possible by using High End fiber optic cabling which researchers did not use, and by swapping out to single ended vacuum tube amplifiers to power the optical transmitters.
This data rate will allow use of stereo DSD 143,571,428 which is expected to be a substantial improvement over DSD 1024.
Japan hits broadband record
402 terabits per second down fibre optic cables Japan's National Institute of Information and Communications Technology (NICT has achieved a staggering data transfer rate of 402 terabits per second (Tb/s) over commercially available optical fibre cables. The groundbreaking feat was d...www.fudzilla.com
