My theory is that the washing machine actually creates a brand new sock by collecting all the little bits of thread that come off the existing socks and knitting a new one.
Given the tire sizes, I suspect it is a sports car of some sort.That is really not funny. If this is real, it is totally irresponsible! I can imagine my wife looking at this sticker and doing exactly what it recommends.
The 40lbs pressure in the tires, the 150mph or both?That is really not funny. If this is real, it is totally irresponsible! I can imagine my wife looking at this sticker and doing exactly what it recommends.
Yes, but what is over-inflation. Many tires now have 50 psi max even though your car may specify lower pressures for most driving. My understanding is tires at lower pressure generate more heat at high speed. So increasing the pressure as long as it is not too much is helpful. Higher pressure also helps in cornering at speed so the tire stays on the rim. Not as much an issue with modern extra wide tires. The SCCA suggests raising tire pressure 10 psi when taking part in their events to prevent damage to the edge of the tire in high G cornering.Both? Correct me if I am wrong, but if you overinflate your tyres and drive at high speed, the heat increases your tyre pressure even more. This would cause the tyre to balloon and reduce the contact patch, not to mention ballooning from the centripetal forces at high speed. Either way - less contact patch, potential for tyre failure from overinflation + high speed will lead to disaster.
The part of the tire that enter in contact with the road suffer a deformation and again when leaves the contact with the road. This produce the heating of the tire.Both? Correct me if I am wrong, but if you overinflate your tyres and drive at high speed, the heat increases your tyre pressure even more. This would cause the tyre to balloon and reduce the contact patch, not to mention ballooning from the centripetal forces at high speed. Either way - less contact patch, potential for tyre failure from overinflation + high speed will lead to disaster.
I just keep it below 145. Problem solved!What I find confusing is how am I supposed to increase the tyre pressure when approaching 150mph? I can't get out at that speed.
S
