That there is every kind of people. Not everyone likes lateral reflections.
Like I said before: so?
I was
replying to a question about whether to maintain the same lateral reflections treatment when moving from stereo to multichannel with front wides. Which you
commented on, that "it's only personal preference", then expanded on this with "there is every kind of people". You aren't taking the conversation anywhere useful.
If I was replying to a question about smoking and lung cancer, and I said that the science is telling us that smoking is a bad idea if you don't like lung cancer, would you think it is smart to chip in with "it's only personal biology, my grandma was a chain smoker her whole life and lived to 99", and "there is every kind of people, biology is personal, I smoke and I don't have lung cancer"? That would be about as unhelpful as it gets.
The science tells us what course of action is the
safest bet to take at the individual level. It doesn't guarantee that outcome at the individual level.....but sometimes the confidence is quite high. (If it was all just random personal preference, then science wouldn't bother to issue a finding at all, and would conclude that "a correlation was not found", or "there is most likely no correlation", depending on the evidence and design.) In the case of lateral reflections, the conclusion was
not that "everybody hears it differently and randomly". So the
best bet is the advice I gave.
Now, of course, if one is not satisfied with applying the confidence level underlying the science-forward advice to oneself, one can increase the confidence level by conducting the experiment on oneself at home.
That's a wonderful idea, but there are two points worth making:-
- Not many people can be bothered to properly test themselves at home, so most people are well served by adopting the science-forward advice as the best proxy for a personal experiment, with good confidence.
- The home test had better not be sighted listening, because the confidence level for that method is way less than if they had simply followed the science-forward advice. I bet the feedback forms of formal audio experimenters are littered with comments like "I was so shocked by how I scored in your (controlled, randomised, experimentally valid) test. I was so sure I was going to score the opposite, based on what I thought I was hearing in sighted listening tests at home."
From my POV it is most likely that your personal findings lack the rigour of a formal experiment, and if so, it would actually be more likely than not that you would have the opposite result if you had been one of the participants in the formal experiments. That's how unreliable are sighted listening tests at home.
Finally, even if one had successfully conducted experimentally-valid personal listening tests at home, with speakers with excellent spinorama, and concluded that one does not like near-side lateral reflections with two-channel stereo, bringing it up here is helpful in what way? The science still stands: its recommendation won't be changed by one extra data point. The confidence of the science-forward advice to the readers is not changed. And readers can be certain that your personal (minority) preference has zero applicability to them personally in determining their course of action.
It bemuses me.
cheers
