A Broad Discussion of Speakers with Major Audio Luminaries
The audibility and audible effects of early reflections are undoubtedly important, which is why many years ago Sean Olive and I conducted extensive experiments to determine those thresholds.
Olive, S. E. and Toole, F. E. (1989). “The Detection of Reflections in Typical Rooms”, J. Audio Eng. Soc., vol. 37, pp. 539-553.
The abstract is:
“Reflected sounds influence the timbre and spatial character of live and reproduced
sounds. Most investigations of reflections have focused on the performance of live
sounds in large halls. Current interest in the acoustical interactions of rooms, loudspeakers,
and listeners requires further and possibly more relevant data than have been
available. In this study, the effects of reflected sounds were examined as they would
occur in stereophonic reproduction in rooms of domestic or control-room size. Thresholds
were determined as a function of level relative to the direct sound, the angle of incidence,
spectrum, the temporal form of the signal, and reverberation. The relationships between
audible effects and measurements, such as energy-time curves and frequency response,
are discussed.”
If you read this, and some of the data from it repeated in my books (Chapter 6 in the 4th edtion), it is evident that common interpretations of the Haas effect, Haas kickers, the effect of additional reflections, etc. are simplistic or wrong. The widely assumed “fusion zone” of 30 ms applies only to speech in an anechoic environment, yet it gets trotted out for numerous applications involving music in rooms. Few people have taken the trouble to understand the established science, and persist in perpetuating old school notions.
I'm well aware of your study. One limitation of the study is that the acoustically treated “RRF” condition is not described in sufficient detail to establish its frequency-dependent behaviour. The paper states that movable drapes were repositioned and “a few patches of sound-absorbing materials” were added to attenuate early reflections and reduce reverberation, but the type, thickness and absorption characteristics of these treatments are not specified. Therefore, while the study clearly compares a normal room, a relatively reflection-free room and an anechoic condition, it does not provide a controlled comparison between broadband absorption, frequency-selective absorption and diffusion.
I'm wondering if you are misinterpreting what Don Davis wrote about the Haas effect if that was what you were referring to. He defined the Haas effect in the same paper as the following:
"The Haas effect is the inability of the brain to discriminate between echoes and delays of sounds that arrive approximately 10 to 20 ms after the original waves."
"The auditory system temporarily fuses sounds in this 20-ms zone"
There's no indication that he says discrete reflections cannot be heard. Quite the opposite, he strongly believed they were, and LEDE was very much about avoiding such reflections with a certain time window to hear the recorded signal better.
Davis appears to have regarded around 20 ms as a particularly useful delay: long enough for the direct sound to establish clear localization, yet still within what he considered the range of maximum Haas effect. He also noted the coincidence that Beranek had identified a similar ITDG (around 20 ms) as characteristic of the best concert halls at that time.
The Haas kicker/trigger was an experiment early on before diffusers arrived. The idea was the with a strong late arriving reflection, it would cover over many of the late arriving reflections. The mind hears the first strong reflection a lot better and thus naturally isn't able to focus on the other ones. It was an attempt to avoid making rooms dead with only absorption of later arriveal reflections. It works that way also IMO (have tested it), but the strong first arriving reflection is also detrimental. And it was disposed when diffusers entered the scene. So it basically wasn't part of what the LEDE eventually developed into, but an experiment along the way.
This confuses a number of things. Concert halls need diffusion to convey the orchestral energy to all parts of a widely distributed audience. What is heard in a concert hall is a complex comb filter that is very pleasant, but mostly for those who can afford the good seats. Not all reflectied sounds are perceived the same way. The reflected sounds that create the desired envelopment arrive after delays of 60-80 ms and more, arriving from about 60 deg (in the good seats), not 20 ms arriving from the rear in a LEDE room. As shown in the above paper and in my books the precedence (Haas) effect is very different for different sounds, and it changes enormously with the addition of reflected sounds whether they are in the room or in the recording. There are no “single number” generalized solutions. The Haas "kicker" is a based on a significant misinterpretation of published literature, as was tested in the above paper.
I think this may be missing Davis's actual point. He was not arguing that a LEDE control room should reproduce the same reflection pattern as a concert hall, nor that all desirable spatial effects are produced by a single 20 ms reflection. His point was that the LEDE principle could produce an initial delay gap in roughly the same region that Beranek had associated with the best concert halls, and that Davis regarded this as coinciding with a favourable region for what he called the maximum Haas effect.
Also, the research on concert halls does not seem to support such a simple contrast between reflections around 20 ms and desirable spatial effects appearing only at 60–80 ms. Barron's experiments showed that lateral reflections could produce spatial impression over a broad delay range of approximately 10–80 ms, with direction and level being at least as important as delay itself.
This is also consistent with the work of Schroeder, Gottlob and Siebrasse, whose comparison of European concert halls found interaural coherence to be a much stronger correlate of subjective preference than ITDG alone. Ando's work is also relevant here. While he did not propose a universal optimum delay, his preference studies showed that the preferred delay of an early reflection could fall around 20 ms under particular conditions. More generally, he found that the optimum initial delay depended on the temporal characteristics of the music, as well as the total strength of the early reflections and subsequent reverberation. Thus, a preference for a delay around 20 ms is not inconsistent with Ando's work; it is simply not a universal rule.
So I agree that there is no single-number solution, but that cuts both ways. The concert-hall literature does not support the idea that the desirable spatial effects are uniquely associated with reflections arriving at 60–80 ms or later. Early lateral reflections, including those in the region around 20 ms, can clearly contribute to spatial impression and subjective preference, depending on their level, direction, temporal structure and interaction with the rest of the sound field.
Diffusion of the sound field in listening rooms is of no benefit. In fact, if too energetic and from the wrong direction it degrades the delivery of directional and spatial information encoded in the stereo recording. Reflected sounds arriving from the sides are most effective in creating impressions of space - that is how the binaural hearing system works. Even a single synthesized reflection from the side in an anechoic chamber is perceived as "spaciousness" not comb filtering. Humans are programmed that way.
Diffusers in small rooms should be used to attenuate reflections by sending most of the energy off in other – hopefully non-destructive – directions. However, the energy remains in the room, which may not be an advantage. The performance of diffusers that matters most in small rooms is how they alter the attenuated sound reflected in the direction of the listener, a performance factor that is rarely specified. The gratings cause spectrum changes and phase shifts in the reflected sound. Fortunately humans are not sensitive to phase shifts, and the magnitudes are trivial compared to the delays involved, but the spectrum changes in some diffusers are significant. Peter D'Antonio has discussed this and published some data.
I think this is where your argument becomes too categorical. Your an Olive's experiments on reflection audibility were highly valuable, but they did not, as far as I can see, compare specular reflections with the same reflected energy redistributed by physical diffusers. A diffuser does not simply “leave the energy in the room”; it changes the spatial and temporal structure of the reflection. That distinction seems particularly important given the extensive research showing that lateral and temporally distributed early energy can affect spaciousness and preference. D'Antonio and Cox, for example, explicitly describe diffusion of early reflections as a means of mitigating coloration, image shift, harshness and acoustic glare.
And as desribed earlier; the type of diffuser and how it's used matters greatly. In LEDE rooms, they were used only for late arriving reflections (rear of the room). And while it isn't possible to attain the same result as shoe horse concert halls, there's still diffused energy that arrives, but laterally from the rear as oppose to from the front. Not quite the same, but still highly audible.
Diffusers used this way don't interrupt with the IDTG of the recorded room but adds spaciousness while dealing with late high gain reflections. Very seldom do you see a diffuser used this way change the frequency response much. If deviations happen they are generally very narrow and likey not very audible, if at all. A moden diffuser has been improved compared to the old standard QRD.
That being said an absorber is spectrally more neutral and would be the better choice if one only focuses on the frequency response. But as those of us who have epxerimented with different types of treatment; if only absorption is used for later arriving reflection we end up with something mush less preferable.
I understand that you are in the business of selling acoustical devices, and I hope your business prospers, but what is stated in this quote are your personal opinions - subjectivity.
I have my opinions too, but from the time I began my research in 1966 I have used the opinions of others, hundreds of them in controlled experiments to focus attention on specific variables. The accumulated data provide a basis for understanding the relationship between what is measured and heard. A single omni mic in a room is not the same as two ears and a brain, and raw ETCs are spectrum blind, not providing the necessary information to assess the audibility of reflections or the multitudes included in diffuse sound fields. The final answers to all questions are not yet discerned, but a genuine scientific approach is needed to clarify those remaining.
In the meantime, so long as recording engineers listen in circumstances that please themselves as individuals the opportunity for the recorded art to transfer to the listener in typical domestic rooms will remain a lottery. An extreme example of this is described in Section 12.5.5 in the 4th edition, where Blackbird Studio C is described and discussed. The design goal for this extravagantly expensive space was to provide George Massenburg, an influential recording engineer, with a wide sweet spot and an acoustically immersive experience. Peter D'Antonio, a genuine expert on diffusers, designed a room with all surfaces covered with 1 m deep broadband 2D diffusers. Sadly, after the effort and expense no new knowledge appears to have emerged. Recording engineers apparently adapted to the unique sensations of the room, and it was (is?) used as an Atmos mix room. Whatever is heard in this room it is not replicated in any audiophile listening space - the ultimate target audience - much less in the rooms occupied by masses of everyday audio enthusiasts, who should be the target.
The widespread use of near-field listening, with or without acoustically dead, reflection eliminated rooms is the extreme opposite of the Blackbird studio. The middle ground is occupied by countless variations.
Recordings need to work in ordinary rooms or they miss the target audience. Now that most listening is done using headphones that argument becomes a somewhat academic question.
At least there are strong indications that monitor loudspeakers have moved in the direction of "high fidelity", neutrality, technical accuracy. This aspect of the circle of confusion is showing signs of rationality.
I do sell acoustic products, but I do not sell to my customer base here. My customers are almost exclusively in Norway, and primarily in the professional sector. I also develop loudspeakers and would probably have far greater commercial potential by promoting multiple loudspeakers and selling into the audiophile market. My interest in this discussion is therefore not related to any financial benefit.
Blackbird Studio C has little in common with a LEDE design, and I do not think it is particularly relevant as an example of diffusion in small listening rooms. Covering virtually all surfaces with very deep 2D diffusers means that the reflected energy is repeatedly redistributed and diffused. This is essentially the opposite of the LEDE approach, where preserving useful reflected energy was important and diffusion was used in a much more controlled manner.
Such an extreme application of diffusion may well create a highly immersive and unusual acoustic environment, but it is not surprising that it could also compromise the precision of the stereo image. It was an interesting experiment, and I am sure Peter D'Antonio learned from it, but I do not think the apparent shortcomings of this extreme room can reasonably be used as evidence that diffusion itself provides no benefit in listening rooms.
Thank you for the thought provoking post, @Bjorn.
We are off topic here, but I want to add a few more points.
I think there are several issues with using the anechoic single-reflection experiment as a general argument for reflections in ordinary listening rooms. A direct sound plus one synthesized lateral reflection in an anechoic chamber is a fundamentally different sound field from a domestic room containing multiple early and late reflections. The fact that the isolated reflection is perceived as spaciousness rather than comb filtering does not tell us whether the same reflected energy remains beneficial when added to an already complex sound field.
I also think LEDE is being judged partly by the wrong criteria. Its primary objective was not to maximize preference or spaciousness, but to preserve accuracy, clarity and directional information and prevent the control room from masking information already contained in the recording. A sound field that is more spacious or preferred is not necessarily a more accurate monitoring environment.
After experimenting with a high-quality diffuser at side-reflection points (later than 7-8 ms), I find the result clearly preferable to leaving the sidewalls specularly reflective. To my ears, it provides a more natural and spacious presentation while preserving greater clarity and insight into the source material.
Of course, that is only a personal observation and does not constitute controlled evidence. But it also points to what I believe is a significant missing comparison in the research: As far as I can see, the experiments did not directly compare a strong specular lateral reflection with that same reflection redistributed by a physical quality diffuser.
Interestingly, a deep diffuser with wells changes both the spatial, temporal and the interaural structure of reflected sound.
The higher the little marks, the greater the perceived envelopment. Configuration (a) is two loudspeakers set up normally. But look at configuration (b), which has four loudspeakers in front of the listener, two at +/- 30 degrees off centerline, and the other two at +/- 60 degrees off centerline:
Notice that configuration (b) is competitive in perceived envelopment with the best of the configurations having sound sources located behind the listener, including the 5-channel one, configuration (i).
Does that surprise you? It surprised me too!
Oh BTW I forgot to reply that (b) (c) and (d) are all side-incidental arrangements.
If you think of the listener as facing four quadrants of 90 degrees, it becomes clear that the wide speakers in (b) are well within the side-on quadrant. After all, it is only 30 degrees from side-on, but it is 60 degrees from front-on.
I agree that (b) certainly looks like four front speakers, but it's a bit of an optical illusion.
cheers
The entire purpose has been to provide guidance in selecting timbrally neutral loudspeakers, and providing methods by which the bass problem in rooms can be alleviated for one or more listeners. Doing so well requires measurements. Anechoic data on the loudspeakers. In-room measurements at low frequencies in the listening room. The 4th edition of the book provides the latest insights of me and my co-authors.
I decided to order 4th edition for comparison though expectations are not high.
I have 3rd edition which is generic and does not contain practical information for speaker designing and room treatment which would not have been known ca. four decades ago when I started speaker designing and simulator development. For example, "timbrally neutral loudspeakers" is filtered to magnitude responses in anechoic, and everything else was either downplayed due to its lesser importance/significance with music tracks specially selected to reveal certain type of coloration, or totally ignored. This has also had quite unwanted (imo) effect to reviews and discussion on ASR. Recently the content has been approximately the following:
3rd edition does not contain much or nothing about wavefront direction, radiating area, location of (LF) radiators, acoustic parameters revealing clarity and interpretation, measurement of clarity spectrum/balance, problems in dynamics and sound stage due to bad timing, audibility threshold of timing error at L.F. with typical GD spectrums (vented/sealed etc, subsonic filter, lowest XO frequency and order), problems in sound stage due to diffraction and other multi-source effects (and how to avoid), preferred slopes of sound power response and directivity index, preferred slopes of on-axis and listening window as a function of directivity index slope (+case-dependencies), preferred level of directivity index for different acoustic parameters and listening distances, information or application instructions for directive and large LF radiators (+case-dependencies; room shapes, sizes and leaks), preferred shape of (horizontal) off-axis responses with different angles of listening triangle (not just with single speaker test = center speaker in front of the listener), preferred slope of directivity index for casual listening radically off-axis, flush-mounted half space concept (advantages compared to full space), utilizing the sense of touch in listening tests (~limits in audibility with ears only).
I could make the list longer, and some topics may have been covered in the books. I don't personally need that information anymore, but it would provide deeper than short generic story with few graphs and references which are usually difficult to find and evaluate.
You obviously missed the references in the book to studies done by others that showed subjective responses to a "distributed" reflection.
Where did anyone (with authority) say otherwise?
I'm just wondering if you think Toole's phrase, "Recordings need to work in ordinary rooms or they miss the target audience.", was suggesting that mixing environments should mirror end user environments. IMHO it was not suggesting that.
It's possible you are responding to something that was not said.
If I remember correctly, somewhere in the book I said that mixing and mastering are different - mastering is intended to polish the recording to be suitable for the intended audience. Mastering engineers often listen to more "HiFi" loudspeakers in more domestic environments - but not always - there are no standards. Tracking and mixing are what they are, and they are being done in very different kinds of rooms, or near-field or headphones (none).
I'm on vacation now, and spending little time in forums. Cheers,
I have 3rd edition which is generic and does not contain practical information for speaker designing and room treatment which would not have been known ca. four decades ago when I started speaker designing and simulator development. For example, "timbrally neutral loudspeakers" is filtered to magnitude responses in anechoic, and everything else was either downplayed due to its lesser importance/significance with music tracks specially selected to reveal certain type of coloration, or totally ignored. This has also had quite unwanted (imo) effect to reviews and discussion on ASR. ...
But Toole's Sound Reproduction is not a loudspeaker design book. Perhaps you had the wrong impression.
Cheers
Quite an impressive catalogue of things there. I wonder if they are all relevant or just things that could be thought of as relevant. No amount of research can ever solve those questions of course, because - as you eloquently put it - ”I could make the list longer”.
...The "score" may be helpful for the purpose of sorting a big list of loudspeakers so you may roughly separate them into groups, but its uncertainties (error band) well exceeds ±1. It is useless at best, or misleading at worst, when used for predicting whether one speaker will "sound better" than another if their scores are within 1 point (likely even a bit larger IMO) from each other.
I wish someone could use Claude AI to create code to auto-post this response everytime someone brings up the Harman Index/Presence Rating/Tonal Balance Score/etc.
BTW, if you go to Spinorama.org, you will find the Harman Score for this speaker is now 5.7 today, while it read 6.5 on Friday. As a matter of fact, every single speaker has now been downgraded on Harman Score by around .8 since Friday. Given that it's a simple weighted average that's been around for years, and the data for those speakers is likewise unchanged, it becomes difficult to see why we are seeing such a drastic across-the-board revision. What gives?
That's exactly what I meant! Scores have changed and it wasn't based on a new review.
BMR 0.8 lower
Ceramic Mini 1.0 lower
Sierra 1 V2 0.4 lower
Relevance is case and preference dependent. As far as I recall, all listed above are clearly audible, but audibility and significance depend on environment, listening setup (locations etc), music tracks/test samples, SPL, tolerance for different errors and incompatible sound characteristics, preferences related to expectations about fidelity etc. and of course product itself.
My point of view is speaker engineering so I don't have much tolerance to almost any audible or otherwise perceivable errors and "bad" features. All are measurable of course. "Preferred" is much more complex term because it's a range (in addition to case-dependence) instead of a single value.
I can and have designed numerous basic crap speakers with very good spinorama, and we have basic quality affordable JBL and Kef boxes at home with TVs, but that does not switch off requirements, ears and other sensors if I want to dream about "final solution" or design quite okay speakers for someone else with his limits and components.
No amount of research can ever solve those questions of course, because...
Because it cannot be monetized. Professional studies are simply too expensive compared to expected profit. Basic studies are quite limited for speaker engineering, and manufacturers have to minimize component and manufacturing costs, and maximize looks and marketing. I would say that high-quality design can be found mainly in the DIY hobby. Studies could also be commercially biased to support marketing, and strictly within possibilities of the manufacturer.
Loudspeaker cookbooks in FI and EN have been more useful than Sound reproduction though theories/studies are not necessarily referred. It does not make basic science irrelevant, but narrowness of research (such as preference study) should not lead to reactionary behavior or hostility towards subjective observations.
@kimmosto I am curious, as I’m sure others are, about what you think makes a speaker subjectively preferred? I know you have listed many things with regards to directivity and sound power, but what do you actually look for in these attributes? And may I also ask if there are other examples of celebrated speakers, such as the example you gave of the Blade Meta, that you find fundamentally flawed?
No, maxSPL and distortion is related only. Max SPL is the maximum sound the driver can produce before getting damaged. It is the product of force factor (Bl) of motor, the withstanding of suspension system, the voice coil. The driver with big voice coil, strong motor, big cone area, strong suspension is normally the one with high max SPL but it does not guarantee low distortion, especially in lower SPL in midrange if the motor and surround is not optimized for low distortion.
I do not agree that the LFX problem can easily be fixed. Theoretically, it can be solved in the way you and Shoba mentions, but that is in theory. In practice, incorporated subwoofers to speakers is not an easy process technically. Simple low-passing subwoofer and high-passing main speaker is likely a disaster without measurement. And measuring requires knowledge, patience and time and I do not expect a majority of customers have that. Some automated bass management software can help but they cost money also.
IMHO, the product should be evaluated based on what it offers direct out of the box, without any addons or special knowledge. And C6B is a good product, even great for the money, but fall shorts in an important area.
I do not puzzled by the "narrow directivity" design choice. What I want is put a notice that while the measured performance of C6B is great in midrange/treble area, it is not guarantee that every person will like it if wider directivity is what he/she prefers
WiiM systems do subwoofer integration quite well for very reasonable cost.
I may indeed have missed those references. If you could point me to the specific studies you have in mind, I would be very interested to read them. My question is specifically about a controlled comparison between a strong specular lateral reflection and the reflection from a well-designed broadband diffuser (meaning not the older QRD design), including subjective preference and perceived clarity. And clearly diffusion needs to be used for a later arriving reflection.
I'm aware of the study called "The Practical Effects of Lateral Energy in Critical Listening Environments" by Richard King, Richard King and Grzegorz Sikora. In that study they used a highly absorptive styrofoam 2D diffuser, hence not a quality broadband 1D diffuser. The reflection arrived quite early (8 ms), as oppose to how diffusion was used in the LEDE design. It was also conducted in a room with already a lot of diffusion in the rear. Besides, it was basically a null result:
8 listeners preferred diffusion (RPG Skyline)
7 listeners prefered absorption (6" absorber/15 cm)
11 listenerd prefered reflection
Or we could say the majortity (15 listeners) prefered treatment over the reflection ;)
What does aluminum have to do with anything?
Especially a 16x8 mm piece of aluminum, assuming it actually is aluminum. BTW, most crimped "Faston" connectors are plated brass or some other copper alloy and because of the appearance of the plating can be mistaken for aluminum, which is an inappropriate electrical connector material for several reasons.
