It solves the problem of the room corrupting the measurement of the speaker (well, mostly).Thought experiment:
An anechoic chamber is a tool.
Which problem is it better suited to solve, the problem of the loudspeaker, or the problem of the room?
It’s not meant to solve either. The tool historically removed the need for a large open field to take measurements. So weather you use a Klippel, a chamber or an open field those tools solve the reflection problem when taking measurements.Thought experiment:
Since I'm already on a roll hurting feelings, I might as well keep going.
Speakers as a collective whole from just a decade ago compared to speakers of today has a noticeable objective performance gap.
The best speakers of yesterday were all designed using an anechoic chamber.
I believe the gap between the performance of speakers from yesterday and today is largely due to the tooling. The best method of yesterday was an anechoic chamber, but it was super laborious. You had to manually position the mic for each measurement. Then you have to wait for a day of moderate temperature, humidity and wind to take the speaker outside to measure the bass on a 20-30 foot pole and then stitch it together with the initials anechoic measurements. Maybe some had custom toolings that would reduce the time and effort in measuring speakers.
I once tried to do a quasi-anechoic measurement manually just to go through the experience, it was such a waste of my time and never attempted it again, my time is way too valuable for this ancient practice. It's akin to my most recent experience with coding and debugging without having AI to support you.
But today, the NFS is a fully automated robotic arm, you set it up, click the go button and walk away for few hours and you come back with high resolution, high precision results. It makes iterations easy and reliable. Other tools like the Dynaduio Jupiter enables faster measurements as well.
Almost no one has a Klippel NFS, so it would be strange if that is the main reason speakers has improved the last decade. To my knowledge for instance Dutch&Dutch does not have an NFS, to pick just one speaker that is universally considered objectively good on this forum. Does Revel have one? I don't know. Kef? Not to my knowledge.
Very careful with choosing my words, especially on the Internet:Since you have pointed out that you are careful with your words, I see that you don't explicitly mention the Klippel NFS as that better tooling you are talking about, but it seems implied in your text.
I also want to add that when I say tooling, I don't just mean measurement tooling. For instance, FEA with Comsol, where the acoustic module didn't become available since mid-2000's. It enables faster prototyping, companies like Perlisten was able to use Comsol to POC on a computer first and it helps them understand design behaviors as often times complex physics isn't always clear how it would behave. Other tools include vibrometers, which I believe Ascend also used to measure cabinet resonance.But a good anechoic chamber is certainly accurate enough to design SOTA speakers. And we have evidence of great measuring speakers even from "horrible" manufacturers like B&W from back in the 90s. So it has certainly been doable for a long time, no Klippel NFS required.
'Mops the floor' - no I wouldn't agree. Incrementally better than the best from the late '70s on, then yes.I would hope most people on ASR would agree that speakers of today mops the floor of speakers of yesterday, at least from an objective performance perspective.
When I see spins like these in modern day speakers relative to the best of the best in the 70's, 80's and even 90's, it does make me want to use the term "mops the floor".'Mops the floor' - no I wouldn't agree. Incrementally better than the best from the late '70s on, then yes.
You have a different opinion on why speakers have gotten better, you don't seem to believe it has much to do with tooling. In such case, I would like to hear your opinion as to what you believe the key factors today that makes speakers better than of those from yesterday.
Of course they do. I have been to one of them but believe they have two.Does Revel have one?
Yes, I was referring to tools as a whole:I commented explicitly about the Klippel NFS, since again that seemed quite heavily implied in your post. If you were referring to tooling in general and not Klippel NFS specifically, I would agree that it's at least part of the equation.
The other major component is that information is more readily available and accessible (aka internet). This makes it much easier to learn / educate yourself on just about anything (not only loudspeaker design).
For sure, relatively recently compared to the 1960s and 1970s. While REW was introduced in 2003, I don't think it offered a lot of the speaker-measurement stuff that we currently take advantage of until later. ARTA came out in 2006. LEAP/LMS came out in the mid-1980's. There was some DOS based software and punchcards even earlier that I have seen mentioned by some people, but I don't remember the name.But I would agree that something as "simple" as REW is probably used extensively by many speaker manufacturers to great effect, and it is something not available until relatively recently
100% no doubt about itI would hope most people on ASR would agree that speakers of today mops the floor of speakers of yesterday, at least from an objective performance perspective.
I disagree. Material is one thing, but there are advanced applications of the materials and advances in manufacturing.Other than flat FR, I don't feel there's much material difference between the designs or yesterday and today. No real advancements in material science. Things like beryllium, aren't new and exotic cone materials, have advantages and disadvantages vs. paper, but all materials are compromised in one way or another and a heck of a lot of high end speakers still use paper, copper coils and aluminum baskets, just like they did in the 60s.
At one point, I was very surprised how Heco produced excellent results even on budget speakers. Now I understand why. Using automated tools doesn't make things better and better. It pushes guaranteed good quality down to the mid- and low-end price segments and makes everything sold sound good, not just six-figure masterpieces.Fun fact: Heco has been using it for years as well. Certainly helped with designing their nice directivity and low distortion speakers, the drivers, and predicting how they work in average rooms.
