A Broad Discussion of Speakers with Major Audio Luminaries
Well yes of course, that’s a given.
But I wouldn’t be surprised if that is generally correct in how B&W designers are approaching things… this “ employing measurements, but ultimately designing by ear for a goal that isn’t related to strict neutrality“ approach would explain the wonky measurements.
i personally think they just make something that's good enough to be loud/have decent directivity and have good low frequency extension, then look for ways to make the speaker "musical" with random bumps here and there that will be smoothed out by 20k dollar tube amps which are load dependent or something
Every B&W speaker I’ve ever seen in a store has been demoed with solid state amplification, and I’ve seen very few B&W speakers in audiophile set ups powered by tube amps.
I think it’s very likely they design in a way that to their ears makes a speaker “ disappear” and has to their mind a vivid sonic signature they feel sound more life-like.
From what I’ve seen most speaker designers are quite passionate (or at least started it out that way) and really have specific goals in mind. Some speaker designers obviously have wonkier methods, or goals not aligned with strict neutrality. For better or worse. :-)
that's weird, most people i've seen with esoteric setups have either tubes or "musical" amps.
marketing speak, they just want to make something that catches the ears of a listener and neutral is "boring"/"sterile".
still a business at the end of the day so i wonder if the marketing team has some input for them or the target consumer's preference (bright "detailed" signature) might influence them or something, and if the designer is genuinely passionate about making shit then more power to them ig. They still sell well from what I can see. Good business at the end of the day
basically more marketing speak for people who are easy to fool with sweet words. He's a rep, not an engineer, his job is to make the product appealing to the target consumers to stimulate demand and he's doing that successfully ;)
A loss of £8 million after tax isn't what I'd call successful.
No doubt the B&W house sound is deliberately engineered to differentiate the brand, but it doesn't seem to be working.
I think you misread the post. He was saying the sales representative was successfully stimulating demand in the original poster.
If he's successfully stimulating demand surely they would be profitable? I'm sure he's stimulating some sales but clearly not enough.
I don't personally think that '8' range are so bad, heard a lot worse. They just sound a little bit unnatural to me in the mid/top. That's also there in the measurement. If forced to I could live with them as they are good in other aspects - Matt Hooper's argument. But then the counter argument is why settle for that compromise when you don't have to?
Come on, you know the answer to this. No need to double down. Stimulating demand in one person with marketing poetry does not mean a company is profitable.
Hi Dr. Toole,
Hope you don’t mind me barging into your thread to ask a technical question I’d like a more authoritative answer on.
I am designing some active speakers with a coaxial compression driver. I noticed that the JBL M2, despite being driven by an active DSP amplifier +crossover, has some passives internally. In particular I am interested in the protection caps and L-pad on the tweeter:
Are there any technical downsides to this approach worth discussing? Does the higher amplifier impedance “seen” by the driver matter in any way for a CD the way it nominally would for a mid or bass driver?
The actual amplifier impedance is still very low so the additional components will not impact the amplifier’s frequency response, but I am curious if there is any benefit to running a CD without any upstream components between it and the amplifier in a DIY situation where blowing the tweeter isn’t a warranty problem, or if concerns about the impedance the driver sees are unfounded for a CD.
Cheers,
Nate
PS—currently very much enjoying a pair of LSR6328Ps in my main system. Still rocking all these years later. Very glad I get to experience the fruits of your directivity research at Harman.
Is this now under DIY thread???
Excuse me, didn’t know we were being that strict around here.
I’m sure in the last 77 pages we’ve never veered off the original topic. ;)
Regardless of my DIY aspirations, I am curious as to the answer from a purely technical standpoint. Does damping factor/source impedance matter at all for HF drivers, or does it only matter insofar as the amplifier itself maintains flat frequency response?
Hi Floyd,
Cheers,
Nate
A few things come to mind.
The L-pad smooths out the driver's impedance peak.
Here is the impedance of a D2 driver mounted in it's lens with no filter (blue), the L-pad only (red), and the complete network (green):
Some amps may become unstable with this high impedance.
The impedance resonances do change the frequency response which could be addressed in the DSP filters.
But the L-pad appears to be damping the resonances seen in the impedance curve, especially in the red trace where I drive the speaker with only the 8 uF filter capacitor and no L-pad. You can see in the red trace the impedance peaks are interacting with the filter capacitor and making additional response unevenness with higher peak at 600-700 Hz, lower trough at 800-900 Hz, and a larger ripple in the 1-2 kHz region. This translates to less filter EQ needed to get to the desired response. Those closely-spaced ripples are hard to EQ. The cost is 9 dB less voltage sensitivity, which in the case of this driver is actually an advantage for me since it plays absolutely terrifying SPL with just a few Watts. :eek: I reduced the gain 9dB for the measurements without the L-pad.
The impedance resonance anomalies are often best removed at the source in my simple experience, although am not an expert on resonances in non-linear systems. I do see a spike in 2nd HD at 600-700 Hz with the 8 uF capacitor, but it really isn't dramatic. I would be interesting if Dr. Toole or maybe @Frank Dernie have comments or considerations about damping these resonances with the L-pad.
This is no big deal on distortion, even if we can see a spike. Perhaps at higher SPL this becomes more dramatic due to nonlinear behavior of these resonances, JBL likely have data but out of self-reservation I won't test that loud!
Thatt 9 dB reduction in sensitivty can be an advatage, the network reduces audible noise allowing the driver to be powered by a range of amplifiers even with elevated noise specs. I actually compared the noise of the driver with and without the passive crossover across a range of amplifiers; PuriFi, Hypex, Bryston, Marantz, and a 1979 Aiwa micro integrated amp :cool: .
I put the mic at the face of the D2 lens, measured ambient noise with an without the L-pad, and compared to the other noisier amps using the L-pad. The Aiwa was thrown in for fun, but actually has acceptable noise with the L-pad. Sorry that the graph is busy with poor colors. Basically the L-pad takes an amp that has barely audible noise like the Bryston and makes it inaudible unless I stuff my ear in the lens.:)
I think the capacitor for both 6dB/oct filter and DC blocking is a great implementation.
I guess the drawback is if you need a larger amp to account for the 9 dB loss in sensitivity. You also need to change the filter capacitor if you want to change the DSP crossover since they are integrated, but this is minor.
I also think it is a tremendous sounding speaker.;) So whatever drawbacks, I think are offset by other tradeoffs.
Incredible reply, thank you!
I also read that the pad actually makes the capacitor DC blocking more effective, as it prevents the cap from seeing an impedance peak that would impact it's ability to filter lower frequency energy.
Reactions: MAB
Hi Dr. Toole,
Cheers,
Nate
MAB gave you a better answer than I could - thanks MAB!
And I agree it is an impressive sounding loudspeaker.
Very thorough response.
My experience resolving problems and dealing with resonance is all in the mechanical domain so your knowledge and experimental data is way over my level!
Voltage generated across the voice coil ("back EMF") is approximately proportional to coil velocity, so if mechanical nonlinearities dominate (as they tend to around the fundamental diaphragm resonance), maximizing this velocity feedback via low (or even negative) source impedance will help linearize the system.
An alternative to the capacitor plus L-pad in active systems is an RL highpass (series R, shunt L), which better preserves electrical damping at low frequencies while still providing high driving impedance at high frequencies to reduce the effect of L(i) and L(x) nonlinearities.
Doesn't the series resistor still cause an increase in impedance as seen by the driver?
In the RL circuit? Yes, but less than in the other one. Assuming an ideal inductance, the shunt impedance goes to zero at DC. Since the source impedance seen by the driver is the parallel combination of R and L, the source impedance is then zero at DC. In practice, of course, inductors have some parasitic resistance, but it will still be much lower than the shunt R in an L-pad.
At high frequencies, the inductor's impedance is high, so the source impedance seen by the driver is approximately equal to the series R. In the M2 circuit, it is the parallel combination of R1 and R2, so will be lower than that of an RL circuit with similar attenuation.
With a well-designed driver like the D2, this is probably all academic. An RL circuit may result in somewhat lower measured distortion (mainly H3 and H5; the H2 is largely due to air nonlinearities), but the D2 as implemented in the M2 already has very low 3rd and higher harmonic distortion.
Thx Keith. I still must be missing something, because both interpretations I've gathered are very amiss imo.
My first, that reflections can arrive before direct...is clearly physically impossible.
And the one you present it might be, previous hangover reflections Lol, seems to be stretching at best..
A speaker is a piece of engineering imo......just a tool.......that I want to turn whatever audio signal into acoustic energy.
I want that acoustic energy to exactly match the electrical signal given to the speaker.
Whatever the signal is...phase corrupted, phase perfect, whatever any of those nebulous terms even mean.....it doesn't matter one iota imo.
A truly technically excellent speaker will match signal completely....mag and phase, impulse et al.
The only arguments against such technical excellence that I see, are the time -is we can't hear phase, small-rooms mask everything anyway, source material is screwed up to begin with....yada yada and more yada.
Well, I say who knows...maybe the reason for all that 'yada why bother' is that we never had the ability to make such phase and time aligned technically excellent speakers before. Muti-way active DSP has truly changed what speakers are capable of.
I say, why not get on board with the idea we can at least make one component in the whole "why bother/can't hear" circle of confusion quagmire ....at least make the speakers.... NOT be part of the problem.
Technical excellence means both mag and phase matter. To the degree speaker phase eventually proves to be audible/inaudible remains to be seen.
Anyone saying it's already proven, is operating under a very subjective state of mind, imnsho.
I don't know if it has already been addressed as i've only read half of the thread yet, but sound can indeed arrive earlier at the listening position than the "direct sound" if it gets transmitted through for example the room's structure/floor.
Sound travels significant faster through solid materials (e.g. concrete: ~3700 m/s) than through air (technically part of structure-borne sound is reflected/diffracted at edges/geometrical discontinuities, change in media/impedance etc as well).
How much is transmitted is dependent of how well a speaker is decoupled. While it is not the same as a reflection off the walls or furniture it can have impact on the low frequency response nevertheless. It can be spotted in an impulse response/ETC as a peak before the main peak if it is serious (ETC favours higher frequencies so it can be hard to spot).
The structure-borne sound transmission particularly applies to low frequencies of course and its impact may be very different depending on the type/material of the floor etc.
While building my studio i experienced this. At higher spl the bass could be sensed as vibrations of the desk and also of the floor through my feet (speakers on cheap stands on the floor).
While i was at it i poured heavy (!) speaker stands from concrete to gain mass (the more the better to reach a lower resonance frequency which is important for this to be effective) and decoupled them from the floor with Sylomer. Vibrations of the floor etc. went away and low frequency response improved.
Cheap & very effective (and also good looking if done right).
A detrimental effect may not be that obvious if there's no LF treatment/long decay times etc., i don't know. But depending on the the type of floor definitely something to consider.
The main benefit though was a very significant reduction in transmitted bass throughout the house/other rooms which alone was totally worth it.
