the amount of boost should relate to the background noise in any specific vehicle.
Just out of curiosity: Did you have the chance to drive the i7, or current RR model based on the same platform? They are quiet to a degree you might want to forget about the necessity of masking any noise by bass boost.
when Canadian Broadcasting Corporation recording engineers participated in double-blind, equal loudness, multiple comparison evaluations of loudspeakers to choose new monitors their opinions agreed with those of audiophiles, and both groups preferred timbrally neutral, resonance- free loudspeakers. The best ones in the test at that time were consumer products, and the professionals were surprised by their choices, some demanding retests using their own master tapes - no difference.
I have taken part in similar (partly controlled) listening tests and even conducted them some 20 or 25 years later, with pretty similar results when it comes to preferred tonal balance. Surprisingly, designated studio monitors of this era were performing much better than high end or hi-fi speakers, which I would prescribe to their sound quality improving dramatically all the way since the early 1990s. Might have to add that all participants were either into recording of classical music, or from the public broadcasting sector, so particularly trained to judge timbre of natural instruments, with very little risk of having serious damage to their auditory system.
The preference for timbrally neutral speakers both on-axis and off-axis (translating to a constant directivity) was also pretty significant, with the exception of some recording engineers preferring the ´B&W sound´ at the time, with no difference between blind and sighted tests.
With respect to the B&W I wonder how your engineers were able to hear the absence of "edge diffraction problems"? Obviously they saw curved surfaces and assumed it.
B&W and other constructions aiming for the same absence of edge diffraction and narrowing directivity, were particularly lauded for:
- accurate localization
- stable localization
- excellent clarity/transparency/detail resolution in the brilliance bands
- wide ambience and excellent depth-of-field
- tonally balanced reverb
The two latter came to me as a surprise, admittingly, and might have been related to the pretty overdamped control room used. There was no difference to the results of the few blind tests, and no correlation between the baffle geometry and the praise for excellent localization/imaging. In fact, the other models which were pretty successful in this domain, looked quite edgy and boxy.
I'll bet nobody actually did anechoic measurements to confirm it. In fact the unbaffled tweeter is a problem, not a virtue. This is why most neutral loudspeakers use baffles and horns/waveguides on tweeters to match directivites at crossover.
We did anechoic measurements, even polar plots, to search for correlation, and yes, freely-mounted tweeters are always a source of inconsistent directivity, I agree. In overdamped rooms with the B&Ws (Matrix generation) of the time, it was not as dramatic as expected, though. The idea of matching midrange vs. tweeter directivity in the transitional band with the help of broad baffles or horns/waveguides is clear from a theoretical point. In practice, most of speakers following this ideal show an increasing directivity index towards higher frequencies, which in my perception leads to more severe problems than it is solving, particularly when judging recordings with natural reverb, as the additional reverb in the listening room inevitably becomes midrange/presence heavy and overly dull towards higher frequencies.
And yes, the B&W in question were delivering kind of the opposite, an overly brillant/bright reverb field (resulting from the tweeter´s pretty broad radiation in its lowest bands and a certain degree of suckout on octave below that), but this seemingly was not really bothering most of recording engineers, nor leading to tonal misjudgment of the recordings. Very few even liked it, and I mentioned them as award-winning engineers who are into classical music recordings and rank among the finest in the world.
If you have ever witnessed the live performance and broadcast downmix of a really really complex work in the control room (Mahler #8, some parts of ´Gurrelieder´ and ´Meistersinger´ come to mind), how a skilled mixing engineer is panning 40+ tracks from spot mics all over the place to a congruent and localizable sonic panorama just by ear, you might also come to the conclusion that these people know how to judge localization and stereo imaging of loudspeakers.
If any want to hear what their mix sounds like through an NS-10M, a B&W or anything else, which is not unreasonable, it can be accomplished by appropriately equalizing a neutral loudspeaker.
That might be the case with current B&W models more or less deviating from an ideal of linearity, but particularly the ones which were pretty well balanced on axis (like Matrix 801 Gen2), in my understanding were creating their specific sound mainly via directivity behavior and indirect sound. So I doubt this can be replicated via EQ, particularly when judging natural reverb on a recording.
The fact that the current trend is to close/near-field listening or listening in reflection reduced acoustically dead rooms makes the task easier - the direct sound dominates. The remaining problem is that consumers don't listen in the near field, so that cannot be the final evaluation.
The overdamped control rooms and use of nearfield monitors to judge a final mix in my understanding were mostly popular some years ago peaking in the 1990s. With control rooms getting additional surround channels being installed and more mixes focussing on imaging/ambience, I noticed kind of the opposite trend of more lively, bigger rooms in studios.
The problem with home listening conditions increasingly deviating from these ideals, of course remains, maybe getting even more dramatic with lots of tiny speakers, bigger and sparsely populated living rooms, increasing listening distances and reliance on digital room correction. Would have expected more of a movement towards effectively suppressing the listening room´s influence with the help of high-directivity index speakers, as they became very popular in sound reinforcement.
